Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
WD My Book 1TB, not recognised by XP
Hi Guys. I have tried various recommended fixes for this - reinstalling drivers, power off/on, use wall socket power. The problem started when I attached a USB2 hub to my computer. Computer has failed to recognise the HD ever since. Any other suggestions??
  • Anonymous Nov 27, 2008
    Somemproblems with WD MyBook
    - computer doesn't startup (XP home) when WD MB is connected bij USB 2.0
    - write errors
    - suddenly not recognised anymore
I had this same problem, it worked then just stopped. So i bought a new USB card and that worked fine. But know all the old USB ports works aswel. Weird...
Posted on Sep 26, 2008
I have a brand new WD 1TB My Book delivered today not recognised
Pleaes open the Device Manager and right click on the Yellow exclamation mark.
Now, click on update Driver and select Install from Advanced Location.
Type the Location as C:\Windows\inf and click on Ok.
The Driver should be installed now.
Jul 13, 2010 | Western Digital My Book Essential 1TB...
Light is on but no one is home.
please remove the raw drive from the casing
if its a sata connect it directly to your pc using a power cable for sata drive and a data cable and connect it to the mother board
i am sure it would detect your drive
if no then your drive has lost its firm ware ata module or the rom bin file
if you know how to fix firmware the drive can be up again
pm me if you cant solve your problem
datarecoveryfactory.
Sep 05, 2009 | Western Digital My Book Essential 1TB...
WD My Book 1tb light blinking and nothing else
Hi Lerniefalls,
Unfortunately the guys at the shop are right. Any viable solution will invalidate the warranty except try a new power adapter. The problem is you can't just buy a new power adapter for this device.
If someone you know has the same device(compare Volts and Amps on the power supply) you can test the theory, but would still need to find an adapter to buy somewhere like ebay.
My suggestion, which will also void the warranty, is to simply purchase a new empty enclusure and have the techs move the HDD from the My Book into it. Assuming the problem is in the shell or power adapter this will solve your problems. If this doesn't work, then you know the problem is in the HDD itself and you will definitetly need the help of a data recovery pro.
Feel free to comment back here with you City name and I can recommend a nearby facility if you do need a pro.
Chris
Jun 05, 2009 | Western Digital My Book Essential Edition...
WD 1TB USB 2.0 EXT HD - NOT RECOGNIZED
Hi First things first, is the light on the front still coming on? If not try a new power supply or moving the drive to a new shell as the problem is either in the AC adapter or in the shell.
If the light is on it only confirms that you have power, but first try a different set of USB ports and if that doesn't work try a different computer. If it works on the other ports, no biggy, use it there. If it doesn't and works on a different computer then it's likely your registry entry for the device is damaged, get back to me if that is the case. If it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried these suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Jun 03, 2009 | Western Digital My Book Essential 1TB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Hi i have a WD mybook both the lights on the power cord and the device itself are flashing rapidly and i am unable to acess the external drive. i have tried using a different computer, tried a different...
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Dec 11, 2008 | Western Digital My Book Essential Edition...
Appreciate the direct "Ask Me".
A couple of ideas:
  • initially, confirm that it is the PC's USB ports that is the issue by trying the WD on another PC;
  • try plugging in a flashdrive, camera to your PC's USB port;
  • if it has been verified that the WD works in other PCs and that the USB port of your computer works, then it could be a registry entry.
Please open "regedit":
  • go to HKLM\system\currentcontrolset\services\USBstor;
  • check the value of the DWORD "Start" it should be 3;
  • If the DWORD "Start" does not exist, pls create it. Right click, New, DWORD value, Start, Value Data = 3.
Incidentally, there is Microsoft KB about disabled/disabling USB here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Western Digital My Book Essential Edition...
WD external hard disk appears on disk manager but not on my computer nor on disk management
We had a simmilar problem, the disk was initialised with vista. It does not read on any other computor on our network. I recently aquired a second vista computor and tried it out on that. Sure enough it works. Thus the problem is that if it was initialised on vista, only vista systems will read it and not xp or 2000. hopes this helps
Sep 11, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
334 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
