Question about iLO 3200 32 in. LCD Television
Ilo 42" Widescreen Plasma TV - Has NO TV
The problem we're having is there is NO TV mode. When I cycle through the Input modes I get AV, S-video, YPbPr1 & 2, VGA, HDMI, DTV. All show "No Signal" when passed through except DTV which shows "Scan for Channels". Everytime I do this it always shows 100% complete whith no channels found. ALSO I noticed that when I bring up the menu, only the first three icons at the top of the menu page light up or highlight. Only when I press DTV does the DTV icon highlight. Cables are tight (and work) and I have removed ALL peripherals. According to what I'm seeing this TV does not have TV mode. HELP!!!
  • Anonymous Jan 11, 2009
    i looking for a Y-SUS BOARD for a ILO 42" plasma PDP4210FA1
    can u tell where to find it used or new?
  • 85 Answers
I was told by another tusted repair org. that this brand has to be sent back to Ilo in the original box to them for repair. And that no one has any part parts for this brand.
Posted on Sep 26, 2008
My sansui sv 2102 is ok but not going av mode
Hi JP,
Kindly check the input of your TV by pressing "INPUT", "SOURCE" or "TV/VIDEO" and you should have a list of input including "AV". Hope it helps.
May 05, 2014 | Sansui Televison & Video
Go to av mode without remote in toshiba 27d46 tv
Here is a manual for that tv. Page 27 says to push the tv/video button but that is on the remote. Do you have a tv/video button on the tv itself? If so, push it until it cycles through to the video input you want
http://www.manualowl.com/m/Toshiba/27D46/Manual/33233
Jul 28, 2012 | Toshiba 27D46 27" TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
How to switch to av rca input channel
hi melinda,
u can go to av input by simply pressing the VIDEO button on ur remote. when first time u press the first input may select. press again and again until u get desired input. normally rca input may be video 1 , or video 2 . first check which input are u using. select the same using remote. To return to tv mode just press TV button on the remote.
ok
Dec 13, 2010 | iLO 2600 Television
I set up my 42 inch Insignia plasma, turned it on for the first time (connected to a DVD player in AV mode) and can only get a black and white picture, no matter what I connect as an external source.
Make sure your dvd player is not in progressive scan mode if your using a/v mode. The best way is RGB component input, provided you have the cables.
Nov 27, 2010 | Insignia NS-P42Q10A Plasma TV
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Ilo 42" plasma tv model#pdp4210ea1
my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
Jan 10, 2008 | iLO 3200 32 in. LCD Television
Ilo 42" tv - v-chip code?
Try these codes 8202 or 8205. Hope this help.
Jul 17, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
344 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
