Question about HP Designjet 110plus nr InkJet Printer
COLOUR NOT CONSISTANT
HEY,
WONDER IF YOU CAN HELP, MY WORK IS COMING OUT GREEN.
WHAT STARTED OUT GREY, IS NOW GETTING GREENER EVERY TIME I PRINT. I HAVE PLAYED WITH THE COLOUR AND CHECKED THE INK, COULD IT BE THE HEADS?
THANKS DODIE
  • whinfarm Nov 03, 2008
    My work is also coming out green. I tried changing the black cartridge since it was reading low. That did not make any difference.
    Problem Solver:
  • 16 Answers
Try to do aligment test page. press and hol power buton and pre 3 times the ok buton. change the printheads and ink cartrige.
Posted on Jul 30, 2009
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
Wiring diapgram and color code for clarion drx6475
hey hey,
Dont have a diagram but if you wanna know the colours they are
Red - Accessory Power
Yellow - Battery+
Black - Ground/Chassis
Orange/White - Illumination
Blue - Power Antenna
Blue/White - Amp remote wire
Brown - Celluar phone mute lead
Speakers:
Front Right - +Grey -Grey/Black
Frount Left - +White -White/Black
Rear Right - +Purple -Purple/Black
Rear Left - +Green -Green/Black
Hope this helps you out
Kind Regards
Brad
Jan 01, 2010 | Clarion DRX6475
EUROPEAN!! 2000 ford escort radio wiring diagram!!
I think this will help you out
beause from 1997 to 2002 models follow the same wiring
http://www.comring.biz/forum/cruise_control_99lx.jpg
thank you,
vijay (vote for me)
Sep 24, 2009 | 2000 Ford Escort
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Will only print photos in shades of green and grey.
Not being able to scan properly and improper colors are most often caused by glitches in the software. Try reinstalling your driver with a new updated driver for your machine.
Here is a link to the OEM page:http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
This is the all in one driver. Install this and try again and it should fix it. Let me know if it helps.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Print text is grey not black
Have you tried cleaning the laser? Open the front door, on the R/H side there is a green lever, pull this forwards. Next on the R/H side of the printer pull off the small panel, inside is a green handle. Pull this in & out fully a couple of times to clean the laser lens. Hopefully your prints will now be back to normal. If not then there could be a problem with eitherthe black developer or the PCU. Try printing some horizontal coloured bars to see if all of the colours are affected or just the black.
Mar 16, 2009 | Epson Aculaser C1100 Printer
Did you try?
Tried it but didn't work. Colours brighter but blacks are still grey. The only thing that works for me is if I convert whatever I'm printing to a PDF and print from Acrobat. Use settings: plain paper/high quality photograph and then it looks fantastic. Too bad about this glitch because I love the scanner/copier and the ease of using the machine.
Nov 07, 2008 | Canon MX300 Office All-In-One Printer
All colours are faint. The black comes out grey.
hi clean your cartridges clean your cartridge head nozal with the printer software goto to start-> settings->printers and faxes-> select your printer->right click->properties->tools-> find options like clean cart or nozals.
check printer settings for best ,normal,or draft set as best and try. may helpful.
Mar 03, 2008 | Canon Pixma MP800 All-In-One InkJet...
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
HP Designjet 110plus nr InkJet Printer Logo
81 people viewed this question
Ben Johnson
