Question about Dell Dimension 2350 PC Desktop
Black screen when I try to reboot the Dell screen appears with this: BIOS Revision A01
  • veejae May 11, 2010
    tell me the status of the diagnostic leds on the rear end of the computer tower
  • Francisco Cortes
    Francisco Cortes May 11, 2010
    that's the version of your Bios... please describe in detail what happens right after you start your computer, your only detail does not say enough for a suggestion to be made
  • 57 Answers
Apparently problem has been fixed moving on to new people :)
Posted on Dec 28, 2008
Dell latitude D610. Bios Revision AO6 Anyone Help?
try to remove bios battery on the inside and short the pins with something iron like a screwdriver for a few seconds, remove the battery pack too when doing this, you should be fine after that,
ps. you might need to set some bios parameters when starting up again
Nov 03, 2016 | Dell Computers & Internet
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
Dell D510 still on dell display
Yes, you either have some corrupt or missing boot or system files. Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 02, 2012 | Dell Latitude D510 Notebook
Dell Inspiron 2310 (all in one PC) does not have physical button for brighness control hance i upgraded the BIOS from A01 TO A04. However I am experiencing booting problem frequently. When i run diagnosis...
You may already know this, but make sure you go into your BIOS and set it to all 'default settings' from the main page, for starters. I'll check back later to see if this helped you. Hope so!
Feb 24, 2011 | Computers & Internet
Why won't my Dell E171FPb monitor work? When I turn my computer on the monitor flashes the first screen, the "DV051...Bios Revision A01" screen, then goes black. I'm using a Dell Dimension E310 that's...
Check the power supply DC filter caps, burnt parts, cold solder joints, etc.
If you are going to DIY repair, please read below and look at my album of failed Dell monitors to get some ideas.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 25, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
I have a dell inspiron 9100
It appears you have the latest BIOS revision for your notebook.
That chip is not supported by your motherboard/BIOS revision. You may want to contact dell, or keep checking the support download page to see if they release an update allow you to upgrade.
Nov 10, 2008 | Dell Inspiron 9100 Notebook
Dell Dimension 2350 PC Desktop Logo
79 people viewed this question
Alun Cox
