Question about Epson Stylus Photo R1800 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Until last week my printer printed perfectly using the tray for cds
and today i cant load any cd for printing i m using the same cds putting them correctly at the tray and nothing it try to load going back and front and the red light is on again :S. Turned off and on again the printer and the same problem again cleaned the tray and the head of printer and again the red light still there
plssss help
  • fffevi Sep 27, 2008
    i did exactly as y said but the prob is still there :S
  • Epson Master
  • 1,879 Answers
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Posted on Sep 26, 2008
How to print onto cds
Photo printing on a wide range of Genuine Epson papers, the Epson Stylus C87+ is perfect for ... direct printing onto inkjet printable CD-R and DVD media
Sep 30, 2010 | Epson Stylus Photo R1800 InkJet Printer
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
I'm having trouble printing on cds (they won't load) with my epson stylus photo r220. I've followed the directions, lined the tray up properly. Set the settings for cd/dvd. Tried old and new software.
Depends how long you have had your printer, epson are well know for the rollers that takes the paper in getting worn, and so does the cd/dvd tray, eventually you have to push the tray in by hand to get the thing started, somtimes changing the disk tray helps, if youve got a spare one,
Dec 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Dvd/cd tray same problem as others posted here
My experience (with the R280) MAY have some relevance.It turns out that, should you turn the printer power on WHILE the output tray is in the upper (DVD/CD) position, you get an undocumented pattern of error lights, error message, and no ability to print. The cure (for the R280) is: just move the tray to the lower position and leave it there long enough for the printer to complete its power-up cycle and initialization, after which the green POWER light will be solidly on. Then you can shift the tray to the upper position for DVDs, or go ahead and print on paper where it is. Epson "technical" "support" people all deny that this is the way it works, and they want me to return the printer for replacement. I have confirmed the behavior on TWO different R280s. They also deny that their CD-Label software scatters "CDLabel.alb" files whenever you load a photograph as background, but that's another issue, and fortunately non-fatal.
Jun 20, 2009 | Epson Stylus Photo R340 InkJet Printer
RE: "Epson CD print" software download for R1800
r1800 doesn't support cd printing. Maybe that's why you can't find the disc??????
Jun 06, 2009 | Epson Stylus Photo R1800 InkJet Printer
Need CD/DVD designer/ printing R300 stlyus photo software
I may be able to help. I have the disc with the 2.5Mb CD Printer folder on it. I can email you the folder which contains the install. Let me know. RMS
Nov 28, 2008 | Epson Stylus Photo R300 InkJet Printer
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson 1800- trouble printing cds
Try to print on a sample or spare CD, before that Click Print Position Confirmation Pattern in the Print Confirmation Pattern section.Click Print to print the confirmation pattern on the disc and remove disc..
--Using a metric ruler, measure the distance from the hole to the cross marks labeled A and B. On print cd application click file and click print and select adjust print position, click enter values then select the distance for A into the height (top) box and distance for B in the width (right) box then click on ok
Mar 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
1,185 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
