Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
I can't get my light to come on on my Casio model 2608
My light used to come on when I pressed my light switch, but one day it stopped coming on. Is this a major fix and costly, or can I do something myself to fix it?
Robert
  • jfreeman2nc Mar 09, 2009
    My watch has the same problem. It is almost like it has a separate battery for the light. But it is not because of the auto function the light is not working at all.
To turn the auto light switch on and off--
In any mode, hold down (L) (light switch at 6o'clock/bottom)for about two seconds to goggle the auto light swithch on(auto light swithch on indicator displayyed) or off (auto light swotch on indicator not displayed)
Posted on Nov 03, 2008
  • moyskley
    moyskley Apr 25, 2012
    Your solution does not work on that model :(
How to change from 12hour format to 24hour format on Casio watch la670w?
How to Set Casio Watch
specifically step 6 below for your answer
Setting Instructions for Electronic Watches
Casio electronic watches feature many different modes ranging from timekeeping to stopwatch. The M button controls the modes. Here is how to set time on a digital watch such as models 1632 and 1813:
  1. Press the M button to get into the Timekeeping mode.
  2. Select the seconds digits by holding the A button down until the seconds digits flash on the display.
  3. As the digits flash, press the C button, which will reset the seconds to 00. On some watches such as GW-500A, a stop/start button is used instead of a C button.
  4. Press the M button and change the selection in the order of seconds, hour, minutes, year, month and day. Proceed in that sequence to change information to the current time and date.
  5. As the sequence progress, digits flash when selected. Press the C or stop/start button, to increase a selected number or the B button to decrease it. Hold down either button to increase the speed of the selection change. All time and date functions are set this way.
  6. Press L when any digit is selected to switch between 12-hour and 24-hour formats.
Jul 08, 2015 | Casio Watches
G shock 2688. How do I turn the light on?
PDF]Operation Guide 2608 2638 2688 - CASIO.
ftp.casio.co.jp/pub/world_manual/wat/en/qw2688.pdf...
Jul 04, 2015 | Watches
Can not change from 24 hours mode to 12 hours mode on CASIO DW9052-1B
1. Press [A], the top left button, and the seconds should start flashing 2. Once you have some digits flashing, press [D], bottom middle button, and will switch between the 12h/24h formats 3. Wait a few seconds and the digits should stop flashing and return from the time set mode, to timekeeping mode.
Here is a link to a manual directly from Casio, showing you all of these steps. As per the explanation on top of the manual, this should work with 3 different models of Casio watches, including yours. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1659.pdf
Have a good day
May 06, 2011 | Casio G Shock DW9052 1V Illuminator ...
My son has a Calypso watch model no. k55506/2 We have a problem to set the time. I search for Calypso and keep getting directed to Casio. Is a Calypso watch a Casio model? That's no problem. The...
This also drove me crazy. But I figured it out:
1. Hold the top left button down until "LIGHT" appears at the top; now you are in the setting more. you can turn the light function on or off by pressing either of the right hand buttons.
2. Then, just keep pressing the bottom left button to toggle through each of the settings (date, hour, minutes, etc.); and use the same right hand buttons to set them as needed.
3. When you're done, press the top left button again to complete your settings.
Mar 16, 2011 | Casio Baby-G BG370S-4V Wrist Watch
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Have a casio model 2608 and its one hour too fast. this is supposed to be a atomic watch that receives the signal and sets itself...help?
    It may be that you watch is set to daylight saving time (DST). If you don't have a manual telling you how to remove this, you can get instructions from the Casio web site.
    Go to the casio web site "casio.com".
    Select "support" and the "manuals", watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Click on "search" and the download your instructions.
    Feb 14, 2010 | Casio GW1500A-1AV G-Shock Atomic watch
    Need to replace casio atomic solar watch 2608 gw-300
    Check out this YouTube video which walks you through the battery change process:
    http://www.youtube.com/watch?v=ogCz2vjUKVg
    May 14, 2009 | Casio Watches
    How many batteries ?
    I just replaced mine, same model, there's only 1 battery in it.
    Jul 27, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio G-Shock GW-300 2608
    Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
    After changing the battery I can now press the light switch button and the watch works normally.
    Tony
    Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio GW300 (2608) battery replacement
    Hey all. The charge provided by the solar cells on the watch only really extend the life of the battery. The total run time of a battery depends on how the watch is used... backlight requirements etc. The battery will be depleted and need to be replaced.
    Here is a site that has good instructions on how to change the battery in your G-Shock watch.
    http://forums.watchuseek.com/showthread.php?t=20217
    If you want to ensure you still have a the same water resistance rating, I do suggest that you take it to a watch guy to have it replaced for you. They clean switch contacts also and you keep water resistance rating. Good Luck and vote this as a "FixYa". Cheers
    regards
    Graeme
    Jan 04, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
    434 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
