Question about Apple Wired Mediapress X SDI MPEG Encoder for PowerMac G4 and G5 - Mac 01MPX001
Applemac black powerbook electrical connection
My electrical connection to my portible adapter model no.m7332 is broken and i need a replacement or to be repaired for my applemac powerbook. I am in cochin india
  • 40 Answers
Contact Apple India for replacements:
Posted on Mar 02, 2009
My old g4 powerbook is dead, power supply seems to be alright , all battery lights come on on the back but nothing from pressing the power button, no noises , black screen....
HI Nick, I had a similar problem with my Titanium G4 Powerbook in the past. The batterry lights showed OK, and at first glance the original Apple transparent saucer shaped power adapter seemed to be working. But then I realized that the very thin conducter wires were broken where the flexible wire meets the connector plug. I cut into the plastic insulation and soldered the wires-a very tedious exercise I might add. This worked for a few weeks, and as I was at sea on a ship, it kept me going. But before long the same problem occurred-an apparent dead computer. I solved the problem by purchasing a 65 watt power adapter from PowerbookMedic. It was dirt cheap and I haven't had a single hiccup since, and that was 3 years ago. You can always see a Genius at an Apple store, if there is one close to your home. These people are amazingly helpful.
Oct 06, 2011 | Apple PowerBook G4 Mac Notebook
Hi, do i need an electrical cord to plug in to an electrical outlet to connect my syncmaster to my powerbook so that i can display on both monitors? or should the power from the powerbook be enough? thnak...
The monitor needs its own power supply, so it will need an AC outlet.. All the computer can do is send out the video signal to be displayed. If you were hoping to use the external monitor somewhere where you won't have AC power, you're out of luck. Sorry.
Jun 05, 2011 | Samsung SyncMaster 172 N (Black) 17" LCD...
How do i open the ac adapter m8482
Looking at a photo of the unit, I would try to pry it open along the seams with a flat headed screwdriver, or a sharp knife blade.
Unless you are skilled in electronics repair opening the case may not be helpful.
Checking on eBay, enter "adapter M8482", you can buy one for under $15 including shipping, from Hong Kong. US plug, with several weeks delay in the post.
Feb 05, 2011 | Apple ACAPP-D56 M7332 M8482 M8576LL/A...
Charging does not charge
If your Notebook computer battery is not charging, try the following:
  • Reset your computer's power manager. For information on how to do this with your specific model, search Apple Support.
    • Make sure your AC adapter is properly inserted into your laptop.
    • Connect your computer to its AC adapter, shut it down, and then let it charge overnight. If it does not charge, it's likely you have a hardware fault in your computer, battery, or adapter, and you should have it repaired.
    • Test your AC outlet. See if your battery will charge if you plug it into a different outlet, or see if another electrical device will work in your original outlet.
    • Test your AC adapter. Try connecting a different AC adapter to your computer and see if it recharges.
    • If it's removable, test your battery. Try using a different battery with your computer and see if it will recharge.
    • In some of the early PowerBooks, the battery will not charge unless the computer is turned on. If you have an old PowerBook and your battery isn't charging while it's turned off, power it on, put it to sleep, and then see if it recharges.
    If you go through all of these steps and your battery still won't charge, or you can't narrow down the source of the problem, you will probably need to have your computer repaired. However, it may be worth your time to consult Apple Support first. It contains entries on problems with specific computer models and versions of the operating system, including battery recharge issues.
Aug 10, 2010 | Apple MacBook Air Mac Notebook
My printer wont turn on
Dear Sir,
If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU, SMC, or PRAM. Refer to the instructions for your model:
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to the nearest Apple Store or Apple Authorized Service Provider (AASP) for diagnosis. If you plan to visit an Apple Retail store, make a reservation at the Genius Bar using
Thanks For Your Time,
May 14, 2010 | HP PSC 1210 All-In-One InkJet Printer
Want to attach applemac to beosound 3000 what do i
what inputs does the B+O have ? there are various usb adapters with line out outputs, not forgetting the headphone sockets, my laptop (G4 powerbook) has a s-video and that has audio in it.
Dec 06, 2009 | Bang and Olufsen Beosound 4000 Shelf...
The screen suddenly went black while connected to an electrical outlet. Nothing works.
Three immediate possibilities in order of expense:
1) Make sure the brightness is on. Press the F2 key.
2) Screen backlight could be blown out, especially if you can hear the disk seeking, fans, etc. even though the screen is black. Connect your Mac to an external display or TV using the appropriate adapters. If you get an image, you need a new backlight or LCD panel.
3) Entire machine is plotz, especially if you hear absolutely no chimes, disk movement, optical reset, fans, etc. This may indicate a power board or logic board issue.
Sep 30, 2009 | Apple PowerBook G4 Mac Notebook
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
Televison & Video Logo
76 people viewed this question
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
