Question about Monarch 9855 Thermal Printer
#765 problem we have #765 problem in monarch 9855 300dpi barcode printer,how can we solve this&what is the problem?kindly help to us. Thanking you sir.
    Problem Solver:
  • 7 Answers
Sounds like your printhead is bad. ty running a print test by havind eaither tags or labels in the supply. then clear the machine and press and hod down BOTH arrow buttons at the same tiem and then release. a print test will apear and carefully look for the line that reads BAD DOTS ;
if the value is greater than 000 than the prinithead needs to be replaced
Posted on Sep 13, 2009
  • 155 Answers
The error # 765 refers to the printhead has less than 4 bad points, press the CLEAR (ESCAPE / CLEAR) and moves the print to avoid the damage. When the printhead has more than 10 points, the error # 768 appear and must be changed.
Posted on Mar 10, 2009
  • 257 Answers
SOURCE: paxar 9855 print error
You have a format problem. Something isn't correct in your mpcl code.
Error 400 - "The character immediately following { is invalid or not an ASCII character."
Posted on Jun 21, 2009
  • 113 Answers
SOURCE: Attempting to print labels from a Monarch 9855
768 is a bad printhead. It could mean that your ph ribbon is disconnected from the ph, or you actually have too many bad dots to print.
Even if you could temporarily get a workaround for this issue, you will need to replace the printhead if your ribbon isn't disconnected. Contact the company to get a ph sent to you. 1-800-543-6650
Posted on Jun 25, 2010
  • 113 Answers
SOURCE: We have a 9855 Monarch barcode Printer. We are
If the printer display just shows Ready, but doesn't print, there could be a few things wrong.
1 - no data is going to the printer
2 - data is going to the printer, but it is not the printer's native language
3 - cable connectivity issues
4 - wrong cable is being used
5 - if wireless, data is not going to the correct IP
If using a 3rd party application, make sure that you've chosen the correct Monarch printer, as well as printing to the correct port. Sometime people print to LPT instead of Serial, as an example.
If using 3rd party drivers, make sure of the same thing.
To see if the printer actually works, press both of the arrows on the display, at the same time, after the printer is at the ready screen. As long as have the printer configured correctly (ribbon, supply type, etc.), the printer should print out a couple of labels.
  • 113 Answers
SOURCE: MONARCH 9416 300DPI PRINTER
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
  • 8404 Answers
SOURCE: In attempting to print barcodes from a Monarch
Remove the printer driver from your computer ... get the latest driver that is compatible with your OS, reload and try again ...
Posted on Jul 05, 2010
Code 765
Long of the short, this message is stating that you need to replace your printhead. Consider contacting Avery Dennisons's customer service to order a replacement.
1-800-543-6650
Apr 12, 2013 | Monarch Paxar? 9855 Label Printer
Monarch 9855 300dpi installation the printer driver
You can download the printer driver from one of these WEB sites.
http://www.nicelabel.com/downloads/nicedrivers/monarch
http://www.gomaro.ch/Downloaddrivers.htm
Jul 16, 2011 | Computers & Internet
We are using zebra barcode printer TLP 2844 model now a days this printer isnot connected to the port,if printer connect to the port we are not getting print label kindly send how we do solve this problem...
Please follow this link for download a driver http://www.zebra.com/id/zebra/na/en/index/products/printers/desktop/tlp2844.html and you should open youtube.com and type your question in search option then after you can see there are many video so you click on one by one video clip and learn how can you solve your problem?
thanking you
davevipul197
Dec 20, 2010 | Zebra Eltron TLP 2844 Thermal Label...
I need speedy label software for Windows XP This used to ship with paxar monarch printers. The earlier version works only on Win98 Can anyone provide me this ?
You can open up label templates in Word or other word processors. For Word, you can find these on Microsoft's website for free generally.
If you are using Avery labels, they have their own label software package custom designed for their products here: http://www.avery.com/avery/en_us/Templates-%26-Software/Software/Avery-Wizard-for-Microsoft-Office.htm
Jun 23, 2010 | Paxar Monarch 9825 Thermal Label Printer
Oct 26, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Different Crystal output from model 9835 and 9855 Monarchs
Your software wouldn't care whether it's a 9835 or a 9855. It can't even tell the difference. Are your supply settings and communications settings the same for both printers? Any error messages on the display when you print?
Jul 08, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Need manual & driver for a Paxar Monarch 94601P
You can download the manual from the Avery Dennison web site (http://www.monarch.averydennison.com/support/Monarch-9855.asp#doc). You can also download "nice" drivers at the same site.
Jun 28, 2009 | Office Equipment & Supplies
Paxar 9855 print error
Jun 01, 2009 | Monarch 9855 Thermal Printer
Hp designjet100 printer problem
Cheaper to just go out and buy a new unit given the inexpensive cost of printers these days.
May 03, 2017 | HP C7796A DESIGNJET 100 PRINTER 24 INCH
Monarch 9855 Thermal Printer Logo
1,165 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
