Protection light on amp stays on constantly, even when it is toatally disconnected
  • 31 Answers
You will need to have it taken someplace and checked out. If and amp or receiver doesn't come out of protect, that means that there is a fault inside that could damage the amp or the speakers if it completes the power-on process. It most often indicates a blown/dying power transistor/s.
Posted on Sep 27, 2008
2007 town & counrty (3.8) cooling fans staying on
the radiator temperature is broken or cable to it is disconnected ?
if true they are set to run constant the fans to protect the engine from overheating. also check the relay is still seated correctly.
Dec 23, 2013 | 2007 Chrysler Town & Country LX New Cars
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
Does the power indicator light stay constant when power is on or does it flash?? pioneer gm-5400t amp
should stay on . I suspect it is in protection mode . disconnect ALL input rca,s and speakers then try again to power it up. if still no good it could be blown. check fuses etc .
Jun 16, 2010 | Pioneer GM5400T 2-Channel Bridgeable...
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
May 18, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Protection lights stays on and my radio no longer ejects after the installation
The amp is staying on with the car off because the amp turn on lead (remote) is being powered to 12v constant and not 12v switched (from the radio or ignition). CD's not changing could indicate a problem with a defective head-unit.
Aug 04, 2008 | Sony XM-2002GTR Car Audio Amplifier
Nitro 1000 w amp
unplug the speakers and the RCA leads from the amp, if the red protection light is still lit then its 1 of your linear amps blown or mosfet depending what your amp uses..if the red light does go off with the leads all disconnected, then connect 1 lead at a time and check the light,when you connect the bad lead or speaker then the light will come on and you know that 1 needs replacing..hope this helps
Jun 30, 2008 | Nitro BMW-481 Car Audio Amplifier
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Amp stays on all the time
hi. your amp has an internal power supply fault. problem lies in the remote turn on regulator circuit or with the pulse width modulating circuit.this fault definitely needs to be in technicians hands. cheers
Aug 04, 2007 | Infinity Reference 7541a Car Audio...
162 people viewed this question
 Grubhead
Grubhead
