Question about HTC Touch Diamond Smartphone
HTCH Touch Diamon dont ring when incoming call
I have checked settings everywhere now, and cannot make it ring again.
Happened during use of bluetooth headset.After that it stopped working.
  • 3 more comments
  • Madarery Nov 25, 2008
    I have the same problem my HTC touch dimaond does not ring when incoming call and I check everything even this solution but it doesn't work... but if I set the profile to vibrate it works.
  • Anonymous Nov 26, 2008
    What I did to solve it:
    press one of the volume buttons at the left site of the phone.
    You're in the System Volume screen.
    Press the < button at the left top of the screen.
    You're in the Ring Volume screen.
    My volume was 0, so no sound at an incoming phone call.
  • Anonymous Dec 19, 2008
    my problem with the diamond is it does not ring loud enough even though its on max vol..... its just too soft, my p3300 and p3400 was much much louder.
  • don burger Dec 19, 2008
    I am a HTC fan I only use it now no other, my diamond cant ring loud enough even if though its set to max, i heard there is a cab or some file that can be downloaded to fix this can anyone help??
  • Anonymous May 07, 2009
    LOL! it was funny cause when i tried, it worked and so simply too... i had gone through all my settings already and couldn't figure it out!! THANKS!
See the fix Posted by Guest on Nov 26, 2008 - I didnt even know that existed - crazy!!!!!
Posted on Jan 13, 2009
I found the following; Even though I checked all settings under Start->Settings nothing helped.
It turns out there is another setting. Move your finger horisontally over the bottom edge of the screen.
Stop when you find settings. There is a horisontal volume-bar at the bottom.Its most likely set to 0 %.
How someone can design an extra volume setting at this secret plac is beyond me.Is it an attempt to fool the user? An attempt to be funny? Very strange. Especially when you control the volume with 2 buttons at upper left corner....
Posted on Sep 27, 2008
  • lillymarshal Dec 18, 2010
    Thank you!! I have been going crazy wondering what happened to my ringer volume. As soon as I ran my finger across this area at the bottom of my phone it worked. Your advice saved me a trip to the Sprint store. Again Thanks
Thanks, it solved my problem! though does completely beat any logic to have sound control at two places, whatever.
Posted on Aug 15, 2009
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
Low ringing volume during first few seconds of incoming call...how can i solve this
ur mobile incoming call setting u assigned low type.
u change the mobile setting
setting>>profile>>edit >> incoming call >> choose ur type incoming ring type,
( or )
ur speaker problem change it immediately
Sep 08, 2010 | Samsung Omnia II I8000 Smartphone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Aug 02, 2009 | HTC Touch Diamond Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Help me in imate jama problem
hi thanks for using fixya!!
Please check the Bluetooth Settings, then select Mode, you should tick the "Make this device visible to other devices".
Then, select BEAM, then tick "Receive all incoming beams" to enable you to receive datas via bluetooth.
Then, make sure you have enough spaces to your internal memory and external SD card.
Hope this will help, let me know if you need further assistance.
Don't forget to rate me with my simple solution. Thanks!
Feb 26, 2009 | i-mate JAQ3 Smartphone
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
HTC Touch Diamond Smartphone Logo
412 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
