Printer problem my canon pixma ip1000 keeps on blinking green (once) followed by orange (5 times) continuously. On screen it displays Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then back on. Actually i tried it but didn't work.
  • 3 more comments
  • ybanezric Sep 27, 2008
    my problem is this the printer return a message. the ink tanks is full of waste inks.
  • Anonymous Nov 18, 2008
    operator error
  • Anonymous Dec 23, 2008
    Operator error.
  • nafie_sdk Jan 03, 2009
    i have same problem...anybody help?
  • Darshandangr Jan 14, 2009
    green light turning orange-green in canon pixma ip1000
Unplug usb and power connector
open the door and hold power button
connect power
close door and release power button
then power...
Posted on Jan 21, 2009
The solution is that the waste inkt absorber is (almost) full. it needs to be changed
Posted on Mar 05, 2009
  • 3 Answers
I tried all the reset codes and so forth you might find on other otherwise useful forums, and i have successfully modded 5 of these to print on DVDs, but this "operator error" and five yellow flashing lights was a tough nut to crack. I was about to give up and toss it when I tried one more thing and it works!printer problem - biggrin.gif
With the cartridges removed and the printhead carrier in the central position, press the empty printhead's back gently but firmly about a dozen times back against the printhead carrier, pushing it in toward the rear of the printer. I think this may help improve a bad contact between the half a dozen or so rows of little metal contacts on the printhead and their corresponding protruding little metal pins on the printhead carrier. It feels a little spongy (you can feel some give) as you push it in toward the rear of the printer and it gently springs back forward.
This solved it for me. I thought I'd share my idea and successful solution, and I hope it helps you, too.
Posted on Jul 11, 2011
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Canon PIXMA iP1600 Printer
Canon IP3000 error code
read entire solution first, see the 6 modes section.
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
Feb 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
PIXMA IP 3000 service error 5100
to fix it
1. Turn off printer
or: and Also;
I have a canon pixma ip 3000 and i need to empty inktank can u help
Ther is no ink tank it is a counter pre set by canon who decided you can only print so many pages . it is artificial number.
reset your machine by the following should help
read all first
to fix also :
to fix it
1. Turn off printer
or: and Also;
THEN plug it in while still holding both buttons down;
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP1000 Printer - don't work
GO ON LINE
CANON PIXMA iP1000 7 FLASHING LIGHTS
ENTER
ROD
Feb 04, 2009 | Canon Office Equipment & Supplies
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon pixma ip1000 problem
you have to reset your printer
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Sep 26, 2008 | Office Equipment & Supplies
1,748 people viewed this question
jasbo
jasbo
