Question about HP OfficeJet 7310 All-In-One InkJet Printer
Printer cable I have been given an HP all-in-one printer which doesn't have a power cable with it. It was a straight "body swap" and the company which supplied it don't want the original back, even though it was working perfectly. I have a universal adaptor which has a connection that should fit, but want to know if I can safely use it, as it is primarily intended for smaller electrical items such as cameras, toys, phones etc. The box indicates it is suitable for up to 500mA, but not knowing anything about electrical ratings, I don't know if it is okay to use, or about the voltage - the back of the printer seems to indicate 31V, but the adaptor gives a choice of switching up to 12V. Could I use this adaptor with or without a surge protector?
  • Claire2008 Sep 26, 2008
    Thanks, Ginko. Don't know if it is worth buying a lead when the printer isn't under any sort of guarantee (and once I've added postage from the US to Scotland it becomes quite pricey). I thought I was doing my bit to save the planet by "recycling" it, but it will probably be destined for the rubbish tip now. A pity my adaptor can't be used, but I had the feeling it would probably not be the correct voltage.
    Master:
  • 479 Answers
Dont take risk.
contact at this link and know about proper wire for your printer
www.radioshack.com
just click this link .
Posted on Sep 26, 2008
  • HP Master
  • 19,396 Answers
If you use an universal power adapter, you must use one that can provide voltage of at least 30V (25V will work, but better using proper one).
Your 12V adaptor is not enough to power this printer. Buy the proper 31V power adapter.
The replacement costs $12 on Ebay (click).
Or $16 from retailer.
Can not make wifi connection with printer
If the printer is wifi ready, (you did not post the model number) then most of them require you connect them with a cable to the computer and set up the printer for wifi.
Jan 10, 2017 | PRINTER Office Equipment & Supplies
My Dell 3115cn printer will not connect to the network (it still works on USB cable), hard to believe it's broken, so can the printer system be reset?
Try turning off the printer and disconnecting power plug from wall. Hold power on button for about a minute. Then replug unit and turn power on - it should then attempt to hook up to your existing network.
If no go, try reinstalling the software that initially came with printer and was used to set up the network
Jan 10, 2017 | Dell Office Equipment & Supplies
How to download samsung ML-1666 printer driver for windows 7 32 bit
Dear
In windows-7 , the printer automatically down load from samsung website, if the PC detects the printer(try the usb cable conneting from the back panel of the PC). Also you may download from samsung website. Printer Support SAMSUNG India Printer Support SAMSUNG India Printer Support SAMSUNG India
Put your model code on search pocket and click .
Thanks.
Feb 17, 2015 | Samsung Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
I have a hp photos mart d7360 printer and do not have the disk to instale
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select your operating system to download the appropriate drivers and software.
Hope this solves your problem. Thanks.
Nov 13, 2009 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
44 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
