Toshiba 50HPX95 50 in. Plasma HDTV Logo
Posted on Sep 26, 2008
Red light flashing. TV wont start.
I have Toshiba 50HPX95. The red light flashing. TV does not turn on.
  • Anonymous Mar 18, 2014
    when Tv is turned on, the startup menu flashes from one settings to the next.
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Oct 27, 2008
Anonymous
Contributor
Level 1:
Answers
42
Questions
Helped
16039
Points
88
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
I have a Toshiba 50hpx95 plasma tv with a blinking red light. I have already replaced the power supply board and the problem is still there. I need help
I'm no TV expert, but I can share what little knowledge I have, specially what I went through with my plasma TV. It happen in mine, and I got the Y Board fix. When mine was blinking, there was no power, but it wasn't the power board, so searching for an answer in the internet, I found out that it could be one of the boards (Y board or Z board) In my case was the Y board, so I took it to a professional and he fix it for me. IF possible search for: How to troubleshoot TV Y Board.
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
My toshiba 50hpx95 plasma tv makes just a clicking noise from the relays on the power supply but nothing else wont power on and no lights flashing
A common problem with modern power supplies is dryed out capacitors in the power supply, This pulls down the voltage and shuts down the tv. The can usually be spotted if you know what to look for (they swell up and deform a little). It is not a job for the novice. But capacitors are cheap.
Try a local tv shop for estimate
pete
F;lashing power light red, tv wont turn on even after unplugging still wont come
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Red light is flashing on front of tv and it wont turn on
If the red light is blinking but wont turn on . your tv has a defect. maybe the defect is on the board. causing not to osolate.needs a qualified technician to fix your problem.
Toshiba 50HP95
I would contact guy at
[email protected]
he has great expertise and all parts for Toshiba Plasma TVs
5helpful
How to bypass seine card? 50hpx95
Turn off set, unplug power. Remove back cover. On brown circuit board left of center, unplug connector PJ63A. Plug in power, but don't electrocute yourself! If you no longer get the continuously blinking red light, hit the power button. If it comes on, the SEINE module is bad and must be replaced.
2helpful
3answers
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
