Question about SAMTRON 55V 15" CRT Monitor
My pc!s CPU speed is changed
What is the present speed,I have to remember
Dude, this doesn't seem to be a monitor issue.
List the issue appropriately.
If you really want a resolution, describe the issue properly.
Posted on Oct 09, 2008
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
How can i overclock dell latitude D610
Dell limits what the user can actually "control" on their laptops. As such, you can not go into the BIOS to change the clock speed. To keep the CPU running at a higher clock speed, you can go to Control Panel>System Management> Power Options and change the scheme to Presentation mode. Hope I'm not too late and that it helps!
Dec 25, 2010 | Dell Latitude D600 Notebook
Variable speed fans suddenly slow single speed only.
check with the temperature of the CPU core!
because of over heating the CPU is shutting down or not.
Sep 24, 2009 | IBM Computers & Internet
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
CPU speed dropped after installing RAM
Ok. Fear not. You CPU is running at its native speed, it is the fault of Windows reporting the actual CPU speed. If you stop in the BIOS, the real speed will be reported there, the same if you run Linux.
Apr 18, 2009 | Computers & Internet
I am tryin to upgrade my processor on my 4000783 gateway motherboard need to change my fsb speed and dont know how
You cannot change your fsb. You need to upgrade to a cpu with a fsb speed that your board can support. Once you install the new cpu your bios will set the fsb to the higher setting of your new cpu if your board supports it. If you have your board specs it will tell you something like supports fsb 1066/800. That would mean you could upgrade to a supported 1066 fsb cpu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Computers & Internet
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
CMOS Checksum error - Defaults loaded
When the CPU speed stored in BIOS and the actuall speed of CPU differs then this error comes.
To fix this you have to select the actuall speed of your attached CPU to the board. Just set the actuall speed and save the changes. It will fix your problem.
Thanks
Iqbal
Mar 23, 2008 | EliteGroup P6STP-FL Motherboard
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
SAMTRON 55V 15" CRT Monitor Logo
27 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
