Question about Nilfisk Family Vac Bagged Canister Vacuum
My filters? need cleaning
My vacuum cleaner (Nilfisk) is stopping as it is overheating, how can i clean the filters? I have tried but it still has the same problem.
I have taken out the square felt layers and shaken them and i have taken out the pleated plastic one but it doesn't seem to have made any difference at all.
Rosemary
  • 3 Answers
Most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Posted on Feb 04, 2009
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Tip
How to maintain a Nilfisk Combat vacuum cleaner.
The Nilfisk combat is an excellent value vacuum cleaner, to operate at it's best though you will need to look after it.
This is really simple, first remove the hose from the front of the vacuum cleaner and drop a medium sized coin in one end and then see if it drops through easily. If it comes through with no problems then you should check your filters The Nilfisk Combat has 3 filters which need to be checked.
The first filter is at the back of the machine, there is a small door, open the door to reveal the filter. It is unlikely to be causing suction loss but check it and if it has a lot of dirt on it buy a new one.
The inlet fitler can only be seen when you remove the dirt chamber, take out the chamber and look from the front of the machine to the back. There is an oval shaped hole and a small washable filter inside - give it a quick brush off and reinsert.
The Hepa Filter - this is going to be the issue 99% of the time. Now that you have the dirt chamber removed you can access the filter. Hit the button that releases the bottom trap door and let the dirt out (over a bin so you don't mess up the floor). Now you have to take the top part off by twisting the bin Lastly take the hepa filter off and check it over.
There is a shroud that slides off to reveal (normally) lots of dirt and muck caught in the folds of the filter Its a messy job...but you really have to do it if you want your vacuum to work well.
You can try to tap it out on a piece of newspaper or over the bin. Using a brush will work well too. Basically though it needs to be done every few times you vacuum or the dirt will just get lodged in there. If you have cleaned it but there is still noticable built up muck in it the unfortunately it's got to be changed Vacuumspot.com.au or NelsonVacuums.com.au both have this filter available.
The dirt canister has a built in filter cleaning function. It is only really usefull if you do it every time you empty the bin though. In the top of the canister is a big dial - really simple to use turn that thing a few times every time you empty the vacuum. It does not take the place of removing the filter and tapping or brushing it out though!.
on Oct 24, 2010 | Vacuums
How to replace thermal overload switch pacvac 700
Hey there! The thermal protector sensor can not be replaced. It protects the vacuums motor from overheating and burning out. If the vacuum is overheating, follow these quick trouble-shooting steps.
1. Remove the hose from the vacuum from both ends.
2. Use a broom stick to gently loosen and remove any clogs from the hose.
3. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose.
4. Clean the pleated filter inside the dirt cup by tapping it against the trash can until the dirt stops falling. This filter should be replaced at least once a year.
5. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry outside the dirt cup.
6. Clean the secondary filter located behind the grill in the bottom of cleaner cavity. Remove the screw, and grill to access filter.
7. Rinse the filter in cold water with a mild detergent to clean. Allow 24 hours to air dry outside the vacuum.
Following these steps should stop the cleaner from overheating. Hope this helps!
Jun 16, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
My 4 yr old Nilfisk vacuum cleaner has been working fine up until now. But suddenly, it has hardly any suction power and also, hot air seems to be coming out thru the vents on top and also thru the space...
Hi there SmartAlec from Nelsonvacuums.com.au here.It sounds like a blockage of some kind. The best way to find it is to set the machine up for normal vacuuming and remove one component at a time until the suction returns. eg turn on and feel suction under floor head - not good? then remove the rod, then the hose.
Once at the machine on its own it gets a little triky as i don't know which model you have. However if you have a bagged model remove all the filters and the bag and retest. There will be at least 2 filters, one before the motor and one after (maybe under the vacuum or right at the back). If it is a bagless model even though the filter may look clean it is probably blocked with very fine dust. If suction returns when the filter is removed then you need to buy a new filter. I am a nilfisk vacuum cleaner agent so i can supply a filter for you.
If this still doesnt help you are welcome to call me if you live in australia my contact details are on my website www.nelsonvacuums.com.au.
Hope this helps !.
Happy vacuuming :)
Aug 23, 2009 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Overheating while vacuuming - 15 mins near new machine. Have checked filters. No change
When we run vacuum cleaner continuously, it gets hot.
So after each 3-4 minutes cleaning, stop it and remove the dust. This will cool the motor and in this way we can use it for a long time. So use vacuum cleaner with breaks.
May 13, 2009 | Vacuums
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum starts runs normally for a few minutes then stops
depending on the type of your vaccum could have blockage and be over heating check all pipes and hoses and clean filters
Nov 10, 2008 | Nilfisk Vacuums
I am looking for a nilfisk c120.2 pressure hose replacement i seem to have looked everywhere
need to be more specific,is it click an clean tube with tornado nozzel ,or 15m drain&tube cleaner.
Aug 28, 2008 | Nilfisk Vacuums
Nilfisk Family Vac Bagged Canister Vacuum Logo
728 people viewed this question
Top Nilfisk Vacuums Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Thatvacguy.com
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
