Question about Car Audio & Video
I want to wire footwell neons in my car with a switch on my dash to activate them. i know what positive and negative wire ill be able to tap into, but i dont know how to rig a swtch so they can be turned on and off?
  • 185 Answers
Ok well take the ground wire to the metel on the car and remember to get down to the metal and then run positive to a kill switch and run a nother wire to a 12 volt source it really ist hard just let me no if u have any problems my name is pj and plaese rate me
Posted on Sep 26, 2008
I am hooking up an alarm with remote start on my Hilux 22r. I need to know which wires do what on the back of the key start switch so I can tap into them. I need acc, on and start
ACC is on when switch is in ACC position - usually the first stop.
Neither ON or START is active.
ON is the ignition - usually the 2nd position.
START is active when u push and hold the switch past ON. ON will also be active.
Feb 18, 2015 | Cars & Trucks
Front stereo speakers dont know wat one is positve or negative its a 1996 dodge neon????
On the left (drivers) side the dark green wire is the positive and the brown/red one is the negative (ground) On the right (passenger) side the purple wire is the positive and the dark blue/red is the negative. I hope this helps and good luck.
Aug 11, 2011 | 1996 Dodge Neon
1997 mercedes benz slk 230
Car Radio Battery Constant 12v+ Wire: Red/Green
Car Radio Accessory Switched 12v+ Wire: Pink/Yellow/Green
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Gray/Blue
Car Stereo Antenna Trigger Wire: Blue/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under right footwell carpet.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/Brown
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Yellow/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
pls rate
Dec 13, 2009 | 1997 Mercedes-Benz Mercedes Benz Sl Class
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 19, 2009 | 2005 Dodge Neon
I dont know which wires are which in the dash of a 1987 dodge dakota
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: 5′ x 7′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black/Yellow
Left Rear Speaker Negative Wire (-): Gray
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
May 04, 2009 | Car Audio & Video
L Reg Jaguar 3.2 sport automatic gear lever wont come out of park
Solved. Wiring to switch on foot pedal disturbed by removing footwell carpet while cleaning. This switch activates unlocking from park position of automatic gear lever. Thanks
Mar 02, 2009 | Jaguar Xj Series Cars & Trucks
Mute keeps activating by itself
easy guys ill explain, if you pull the deck out and expose the wiring in the back you will see a small pink wire with a plastic and metal end, that wire is your parking break bypass wire,wut i did with my car was created a switch, its very easy, all you need to do is go to radio and purchase a ON/Off switch, it will have only two metal connector ends on that switch, basically all ya gotta do is find a suitable grounding spot for the negative or OFF side of the switch and then for the positive side...you guessed it attach the pink wire to the positive side. I had to make the pink wire longer for my switch location so if you know how to solder I wuld reccomend doing that than any other ghetto method, such as electric taping it and calling it a day, ding that may damage the system in the future
Jan 02, 2009 | Jensen VM9510 Car DVD Player
Need to know factory wiring colors to hook up aftermarket stereo
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: N/A
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Shelves
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Negative Wire (-): Blue/Green
Aug 03, 2008 | 1990 Mazda 626
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
