Question about HP LaserJet 2100 Printer
Laserjet 2100 Won't turn on!
Hi, just acquired a second hand laserjet 2100, all plugged in but won't switch on at all. (came free from friend so no major gripe) Checked socket and plug connections on both ends. Can elec lead be faulty? Is there a trick? Or is it just dead?
  • HP Master
  • 19,396 Answers
Yep, the power cable can be faulty, test a different one on a different socket. Try also playing with the power connector on the printer.
If the power cable is fused, like for example in UK, then check the fuse.
If it still does not give any sign of life, then there is a fault on the power supply board, inside the printer, usually the power supply fuse. Part is about $45 refurbished/$55 original .
If the problem is not the fuse you will need to get a technician testing on board component, and probably replacing a faulty resistor or capacitor.
Posted on Sep 26, 2008
How to reset counter hp lasserjet C4096A toner
Its simple thing to reset your counter volume for ink or print setting values. As latest drivers installation will make to default values from their you can easily reset the values. download and install the latest drivers.
HP Laserjet 2100 Printer Driver Free Download For Windows
May 13, 2014 | HP LaserJet 2100 Printer
How do I download driver for HP 2100 Laserjet
  1. download the most recent version of the PCL 6 driver.
  2. Under the Quick jump to heading click the desired version of Windows Printer Driver.
  3. Select the PCL 6 drive.
  4. Select Save this program to disk and click OK .
  5. Under Save this program to disk choose a location to save the file, note the location, and then click Save .
  6. When the download is complete, the file will appear in the directory specified in the previous step.
To open the file double-click the file, click OK , and then click Unzip . After the file has completed self-extraction, click OK then click Close . follow this instructions
Apr 26, 2014 | HP LaserJet 2100 Printer
Config page in hp2100
On the LaserJet 2100, press the Go and Stop buttons together, then let go, and the configuration page will print out. (You may have to hold them down for a couple of seconds.)
For configuration page instructions for other printers, see the How to Print Configuration Pages web site.
Sep 08, 2010 | HP LaserJet 2100 Printer
HP LaserJet 2100 will not stop printing nonsense when I have cancelled and cleared the print memory. It's going through tons of paper and turning it off, along w/the computer, for several minutes does not...
The "nonsense" is your printer trying to interpret the information. Go to HP.com and download the correct drivers. Delete all other drivers from the Printers and Faxes/File/Server Properties. Then install your correct print driver
Nov 20, 2009 | HP LaserJet 2100 Printer
Laserjet 2100 prints code
Install the HP LJ III driver and this should work as advertised.
May 22, 2009 | HP LaserJet 2100 Printer
HP 2100 LaserJet, was functioning ok, now won't power up, power to AC plug is ok ... Is there a fuse somewhere ? Jim
Remove rear cover and fuser.
Blown fuses usually point to a bad power supply which is the circuit board under the fuser.
Feb 07, 2009 | HP LaserJet 2100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
Need A Manual
HP has a pdf manual online for your model.
Here is the URL link for the HP LaserJet 2100.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=25469
Nov 28, 2007 | HP LaserJet 2100 Printer
HP LaserJet 2100 Printer Logo
624 people viewed this question
Ben Johnson
