WASHING MECHEN PROBLEM ELECTROLUX
SIR WHIL WASHINGMECHEEN I S RUNNING THERE IS LOUD NOISE LIKE TUK TUK WHIL SPININGOF THE DRUM WHEN WE KEEP B C D EF G H IJKL WE CAN HERE THE SOUND THE DRUM ROTATE S SLOOLY THE WASHING MECAN IS THE FIRST MODEL WHICH CAUSED ME THIRTY THREE THOUSAND IN CHANIE
  • 750 Answers
Hi DRVBM
Welcome to fixya.
I'm Huuum and happy to assist you,
Tuk Tuk or banging may mean several things.
Uneven load or over load of cloths, meaning to mush inside at one time.
Or if it is a top load washer and, an old washer it may have a bad coupling connect in it to the transmission .
What's the model number, year of washer and slowly describe the issue!
with the answers to the above questions I may help you more!
Check these!
Is the load balanced and the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
Huuum ,
Please leave a rating at the end
Posted on Sep 26, 2008
Electrolux model EIFLS60LSS.
Malfunctions that produce loud noise requires visual inspection. If is question about new appliances then make sure that you properly remove the screws that block the drum and special plastic holders on the housing through which the screws fixing the drum (described in user manual). If you didn't remove this holders they will produce loud noise and sometimes can destroyed door gasket.
In my country failures of the bearings are covered in the warranty period, except in the case of overloading, which is almost impossible to prove. Unfortunately, for your country I do not know, but I think this can be easily check by phone call to your nearest dealer.
Dado
Mar 09, 2017 | Electrolux Washing Machines
Front loader jumps over the floor and makes loud noise when on spin
Hey friend, thanks for your post!
It sounds like a possible issue within the drum of your Electrolux washer and that is why it is jumping around and making a noise. Is this a new installation? If so, I would suggest checking the back of your washer to assure the shipping bolts have been removed.
If it is not a new installation it could be a potential issue with your shocks or drum and I would suggest seeking additional assistance from a professional for further help. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
Why is my LG TROMM frontloader dryer making a loud noise when running?
If the washer is making a loud noise the rear drum with bearing might need to be replaced. On this washer the bearing might not be sold separately, the entire rear drum might have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Sep 02, 2014 | LG 4925ER1015B 4924ER1010 Used Frontload...
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
EI30ES55JS
Good Afternoon Friend,
I understand you are hearing a loud fan noise in your Electrolux range, model# EI30ES55JS. Typically, a fan will be running if the oven or cooktop area is on. This is to help keep the electronics cool so they do not become damaged. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 24, 2014 | Electrolux EI30ES55JS
Electrolux front washer EWF 1087 bangs loudly at the start of spin cycle
It is so common that the washing machine can make terrible noise in many ways and is a common fault.Check the suspension, shock absorbers and spring mountings, check the levelling of the machine.If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 24, 2013 | Washing Machines
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
We have an electrolux EWF 1087 and the drum is rubbing on the rubber seal causing it to smoke and shudder and making a loud noise. Can you help?
You have a big problem . Sounds like the (spider) on the rear of the inner drum is broken. Means a new drum and rear tub plus about two hours labour to repair.
Feb 27, 2011 | Electrolux Washing Machines
Dryer is making a loud squeeling noise when running
This is probably the drive belt slipping on the drum or motor. There is usually no adjustment on these and it is a case of replacing the belt. If you take the top off the machine, you may be able to look inside while it is running (KEEP CLEAR OF THE ELECTRICS AND DO NOT DELVE INSIDE WHILE THE MACHINE IS IN THIS STATE!) and see the belt slipping. If it is, it's probably time for a new belt
Nov 20, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
