Gestetner 3245 used toner case
Wer can i find the used toner case... wer it located..??
  • 2,794 Answers
Try http://www.precisionroller.com/
Order using the Ricoh equivalent model number which is: af450.
Posted on Sep 26, 2008
My celkon c9 imei soft ware gone
Wer is u r location.wer u buy the mobile.contact outlet r celkon service center.if u r stay in hyd.go to dis addres dsn mega theater opp street u wil find the service center of celkon mobile
Jul 29, 2011 | Cell Phones
Please help we are changing the toner on our copier machine and got an ERROR MESSAGE: used toner case is full.
the waste toner box is located beneath the front cover ( the cover that has Canon and model number ).
Open toner cover and you will see one screw wich you need to remove.
Then, on left side of toner, on top of the front cover, few milimeters from edge is second screw wich you need to unscrew. Usually is covered with white/grey cork made of rubber.
then remove cover, by pulling it in left side then towards you.
Big white box is waste toner container wich you need to clean/empty it.
Hope that helped!
Jul 26, 2010 | Canon ImageRUNNER 3235 Black and White...
How do we reset the waste toneron our c2880 imagerunner after we have emotied it and put it back in? The red light is still on.
The machine has the detection system for the waste toner case. This detection is executed by the waste toner case sensor (P11) prepared at the side of the waste toner sensor.
By monitoring PS11 at the time of closing the front cover, the machine judges whether the toner case is mounted on the main body or not.
The sensor is located just up and to the right of were waste toner is dumped into the bottle. You may need to call a tech to come out and perform this. The cover that goes over this are has 3 screws holding it on. One is behind the waste toner bottle. Other 2 left and right at top!
May 25, 2010 | Canon imageRUNNER iR C2880 Color Copier
Wer i can buy ?
www.mytrendyphone.com
This is your solution! Please vote!
May 04, 2010 | Orange PCMICROSTORE Brand Nokia 5300...
The used toner bottle is full. Where is it
Open the right door,remove the transfre unit,remove the transfre belt unit.The waste toner collection bootle is located under transfer belt section.Remove 3 srews remove the case and use the vacuum cleaner to clean the waste toner empty.
Nov 24, 2009 | Ricoh Aficio 2035 Copier
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
How to calibrate the dv and toner...
Did you use a vaccum on the developer unit???? You may have blown out the ATDC sensor on the developping unit
Mar 02, 2009 | Ricoh Aficio 450 Copier
Gestetner 3245 (used toner case nearly full)
most likely it will be on the right rear. look for a door w/ a couple of screws, there is a white plastic container, empty or replace and put back. should clear on it own when done.
Sep 26, 2008 | Office Equipment & Supplies
IR7095 e000019-0000 error
This is the waste toner container and its location.
Jun 24, 2008 | Canon Office Equipment & Supplies
67 people viewed this question
k24674
jasbo
jasbo
