EPoX EP-8K9A Motherboard
Problem for EPoX EP-8K9A Motherboard
Sound... etc
By mightyreal on Sep 26, 2008
so... what now? you gotta help me! Do you think I can have your phone number I can call you for guidance?? The internet doesn't seem to be consistent either... why would that be? it's being cabled from a netgear wireless router... it's an ongoing issue with the other pc's connected to it too... is it the internet connection (Virgin) or the router?
Cheers
Comments:
Sep 27, 2008
- you're gonna have to break it down a bit more for me man... e.g how do I boot into the BIOS or boot into Safe Mode?...
Solution #1
posted on Sep 26, 2008
Not Rated)
MysteryFCM
Rank: Guru
Rating: 86%, 186 votes
With regards to the internet, thats likely the connection, but Virgin should be able to give you an exchange test account to verify whether it's at your end or theirs. The only thing I can think of for you to try is, boot into your computers BIOS and ensure the onboard audio is NOT disabled. Then; 1. Load the motherboard CD 2. See if you can locate the audio drivers 3. Launch the installer Or 1. Boot into safe mode 2. Launch the setup from the download URL I last gave you for the drivers If neither of those work, I'd be inclined to think you've got a problem with the onboard audio, in which case, I'd suggest trying an external card.
Comments:
Sep 27, 2008
- Sorry for not being clear. To boot into Safe Mode, tap F8 whilst the computer is loading, until the boot menu appears. To access the BIOS, you'll need to tap either of the following (the key depends on the board and varies somewhat) as soon as the machine is turned on; Del F2 ESC F11 F10 DEL amd F2 are the most common.
Was this helpful?
Yes
No
Popular Solutions for EPoX EP-8K9A Motherboard
Questions and Unsolved Problems for EPoX EP-8K9A Motherboard
Do you recommend EPoX EP-8K9A Motherboard?
Answer
Answer
test test don't answer
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
how do i unlock channels on an ntl set top box?
Answer
Hi i need a new motherboard model no W340UI and another model number on the same laptop MT3107b
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
