Conwa DVDS200 DVD player will not read dvds - Televison & Video
4 Suggested Answers
SOURCE: DVD player not reading or playing DVDs
Don't waste your time get a new player. You can pick a new one up for about 60$ or less now. If there is clicking thats most likly the lens is stuck and probably because the electric motor inside is dying. I see this all the time with roms not even worth the time to fix them anymore.
Posted on Jan 06, 2007
SOURCE: Dvd player won't load
I have the exact same problem! I guess this company is no good. If you go to their website they don't even have dvd players on there!
Posted on Aug 05, 2008
  • 916 Answers
SOURCE: error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Posted on Jan 02, 2009
  • 10 Answers
SOURCE: dvd player reads "no disc" after inserting dvd
try getting new av./audio cords and use them it should work then if it doesn't then you need to return it. there is a warranty on most dvd/blu-ray players.
Posted on Apr 18, 2009
Does not read Cds or DVDs
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
Nov 01, 2010 | Sony Computers & Internet
Dvd player will not play dvds
Motor was not working. Disposed of old player and bought another dvd player
Nov 04, 2009 | Televison & Video
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
Dvd player not reading dvds
si reviso bin las conecciones prueve el dvd en otro tv
Aug 24, 2009 | Cyberhome CH-DVD 300 DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Lincoln Navigator Dvd player will not read the Dvds
try cleaning the unit with a disc cleaner.and make sure all dvds are clean
Sep 10, 2008 | 2003 Lincoln Navigator
I need a remote control for a Conwa DVD Player
u need to buy a universal remote of you don't have the original
Aug 23, 2008 | Televison & Video
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
Apr 01, 2007 | Audiovox D1812 Portable DVD Player
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
