Question about SanDisk Sansa c240 MP3 Player
My Sansa player freezes on the Welcome Screen when turned on AND also is not recognized by the computer!! Do anyone know how to deal with this???
  • gurusattva Sep 27, 2008
    Same thing is happening to me! Freezes on Welcome screen when powered up and also, not recognized by computer. Very frustrating.
    Tried to install the updater...it didn't work, it installed, just didn't solve my problem.
Posted on Oct 16, 2008
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Sep 26, 2008
Device not playing
The software/firmware of the player is going to need to be updated. You can download the latest drivers from the sandisk website so pc recognizes it, then download the software/firmware update and transfer it to the player
Apr 30, 2010 | SanDisk Sansa c240 MP3 Player
My sansa player turns on and freezes on the Refresh Database screen. The screen then fades and eventually turns black. My computer won't recognize the player either.
STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and install the Sansa Firmware Updater
this is for mac os version.
Feb 25, 2010 | SanDisk Sansa e250 MP3 Player
Mp4 player freeze
if you can still see and detect it with your pc there may be a newer firmware update to fix this issue try and find the firmware and flashing utility from the manufacturer and see if that helps
Sep 24, 2009 | Digital Mind Corporation iQ Sound...
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Micro SD card is no longer recognized
make sure the card is 1 gb or less - a Sandisk card would be best since it's a Sandisk player
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
Player Freezes on black screen format won't work
Delete everything by formatting it then activate the hold switch, press the power button, turn it on, download a fresh new firmware from the www.sandisk.com site and drag it to the player then connect the player to the computer, then initiate the firmware. try to get the latest one.Hope dis works. RATE PLZ
Jun 13, 2008 | SanDisk Sansa e250 MP3 Player
Welcome screen stuck
Reset the player.
If that fails,
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 locks up in refresh database during startup
if the computer can find ur sansa(or 16mb format) you should rightcliick and format it. this will delete ur music, videos, etc but it will make ur player usable
Mar 17, 2008 | SanDisk Sansa e200 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
