I have a Mitsubnishi Digital TV I turn the on switch and it start to come on and in 2 seconds turns off.? Mitsubishi Projection TV # WS-42311 My email mog009@yahoo.com Thanks, AL
  • 8,617 Answers
Try presing the input/device and the menu buttons on the set both in together and hold for 5 seconds to see if the light will blink a two blink error code then let me know what the code was.
Posted on Sep 26, 2008
  • jarezleake Apr 15, 2011
    I have the same problem with my set. I pushed the input and menu buttons and I got two blinks and two blinks. How can I solve this problem?
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
I have A Wt-42311 Tv problem having is either by remote or switch to turn power on i switch it on starts up and shuts off in 3 to 4 seconds. simple fix or?
Mits sets give codes for different failures. By holding down the menu and device buttons on the front panel you can get a 2 digit code that will tell you what is wrong with the tv. The digits are seperated by pauses. 2 and 2 is common and points to a convergence failure. That's the simplest repair you can expect. Goodluck to you.
Jul 06, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Help with my big screen mitsubishi ws65869 tv
my screen is a right blue with no picture although I have sound it reads "tuner out"
Mar 27, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
