Question about Hoover Vacuums
My hoover belt keeps burning when i replace it. i dont have the manual so i dont know what im doing wrong.
  • dirtdevil Sep 29, 2008
    Thanks for trying to give me a solution but it didn't help.
Probably when you close it back together, there is a piece rubbing against that you do not see right away but could maybe hear it.
Posted on Sep 26, 2008
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
The power drive belt of my hoover u3305-030 vacuum keeps falling off, what am I doing wrong?
Hello
One possible solution to your problem is you have the wrong size belt. Check your belt, it should have a letter on it, if it is old, it may be stretched out. Check in your owner's manual, near the belt area, or on the inside of any cover for the correct belt size(which is a letter). Be sure to check that you have the correct size and if not or if it is old, go to your local home depot($1.89+tax for Hoover Model belts) or any other store you know provides vaccuum belts, and purchase a replacement belt.
Hope this helps and please don't forget to rate
-Chris
May 02, 2009 | Vacuums
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
I have a Hoover z 700 the "see manual" light keeps coming on when im using it! I cant find the manual can you help me?
Hi (dont forget to rate this please)
Go to hoover.com website here:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Paste in the model number: U9145900 and you should be able to find a user manual for this to save (opens in PDF)
Jul 11, 2008 | Hoover Vacuums
Hoover upright windtunnel isnt propelling itself anymore
If the V belt is loose with the handle down, then maybe the idler wheel under neath the belt isn't contacting the belt, may be jammed down, just push on it to see if it moves up and down. Belts don't last very long, you may want to replace both of them.
Dec 29, 2007 | Vacuums
Vacuums Logo
55 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
