Question about Brother Office Equipment & Supplies
BrotherMFC-235C status monitor shows ink is empty,but its new ink,and wont print
I have a new laptop using windows vista .i`m trying to install my brotherMFC-235C .The status monitor shows ink is empty,but its new ink (not original ink,but i have used it before) and it also says its offline.When i go into start,control panel,printer, everything is ok.it wont print out test page.ihave uninstalled and reinstalled and changed usb cable to usb2 cable.What now?
We called asus and we had to delete a filter in the main program.problem now solved.
Posted on Oct 08, 2008
Pixma mg3150 ink there but showing as empty
When using replacement or refill, Canon software will not detect them as new or filled with ink. Original cartridges have chips programmed with "counters" which determines how many times it could print. As long as it is printing, it is not really a problem just press the resume button.
Apr 25, 2014 | Canon PIXMA MP150 All-In-One InkJet...
I have an Epson CX4800 printer. It won't print because there is low ink. My laptop indicates that the ink is low, but won't tell me which color it is. How can I connect the two so that I know which ink is...
What OS are you running? Did you install the full Epson software before you connected the printer to the computer? Is the Epson Status Monitor running on the computer?
If you didn't install the full software or installed a generic Windows driver, uninstall the printer. Then disconnect the data cable. Reboot the computer and go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1326618163.1304563464@@@@&BV_EngineID=ccfkadfdhhmeimgcfngcfkmdhjidfmh.0&cookies=no&oid=58606&prodoid=56291067&infoType=Downloads&platform=All . Download and install the appropriate file from the section marked Drivers and Utilities Combo Package.
If you have a Windows OS, if the Epson Status Monitor is running, the icon for it should be present in the lower right hand corner of the screen (status/Notification area). In Windows 7, it may not be immediately visible, click on the double arrow symbol. Then double-click on the Epson Status Monitor icon and the status window should appear with the ink level indicators in the bottom half of the window.
For a Mac OS, open the Applications folder, then select Epson Printer Utility. Select your printer and click OK. Then select the Epson Status Monitor to get the ink level window.
I hope this helps.
(this is generally faster than using the No Ink spot inside the printer. However the ink levels are approximate.)
May 05, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Hi i have a printer (brother MFC-235C). I changed
No there's no specific drivers for windows 7 either 32 bit or 64 bit, it'll automatically install the device with the default drivers.
details here
If there's a problem with your cartridge or cartridge ink level indicator, then you better clean the cartridge contact points and the contact points on the printer.
Good luck
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Red lights flashing. I dont think the ink is out and i did try taking them out following the instructions and put the same ones back in but it still won't print and the light is still flashing, will it...
Printer wouldn't print if red light flashing. Check status monitor for detail? Are some ink not recognized? Do replacement procedure from status monitor on "How to...". Unplug all ink tank. Plug only one ink tank . See status monitor. Is ink tank recognized. repeat procedure, and add ink tank 1 by 1. How about status monitor then?
Jul 09, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Status Monitor 3
In reply to SOLUTION #1 by Basti i have vista and have forced it to work with this status monitor 3 software i will post how i did it now.
First i downloaded the status 3 monitor so that i could fiddle with the programs and files inside from this link here
http://driverscollection.com/?file_id=24410
Ill skip right to the part on how to fix it you extract the file you just downloaded open the folder it went to right click E_SIINS2 with a bandaid icon goto properties then click compatibility at the top of the new window that opened check the box run this program in compatibility mode for: then in the drop down box below that windows xp (service pack 2) also i checked at the bottom run this program as an administrator and boom it worked i can see my ink and everything.
Jun 14, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Oct 11, 2007 | Epson Stylus C60 InkJet Printer
341 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
