Question about Garmin GPS
NO OUTLET TO PLUG INTO CAR - Garmin GPS
    Brigadier General:
  • 6,966 Answers
Most GPS would have a cigarette lighter adapter to charge the unit while in the car. If you vehicle has onle 1, then it would be needed to pullout the cigarette lighter and use that for the charger. If your unit does not have a cigarette lighter adapter/charger, then pls post back the brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 26, 2008
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
Cobra xrs 9955
The simplest advice is to check the power connections. If connected to the cigar lighter / power outlet of the car, remove & reinsert the plug into the outlet.
Still no luck?
Try powering up the detector in another vehicle's cigar lighter / power jack. If it works - try again in your car. The problem is not with the detector, but rather with the installation in your car.
If wired directly to an accessory terminal or other place in the car, check the connection(s) and cable for damage.
If you can't try it in another car, try plugging another device into the outlet to see if it works or check and replace any blown fuse for the outlet. You should consult your car's owner's manual for the fuse box location - and the location and amp rating of the fuse for the outlet.
Check the power cord. Make sure the cord is fully inserted into the detector - not hanging in the jack. The opposite end - that goes into the cigar lighter / power outlet *may* have a built in fuse in the tip. You should check to see if the center tip of the plug unscrews to provide access to the fuse. If it does, replace any blown fuse with the same type and amp rating and try again.
If you were unable to check in another car and you are still unable to power up the detector, there may be an internal problem with detector itself. In this case, contact the manufacturer for additional help.
Jun 06, 2013 | Vehicle Parts & Accessories
Charges at home on a usb port but not in the car
Hi Carl,
You should check your car's fuses to see if the one that supplies power to your USB charger is still good. If you're not sure how to do this, you could try plugging a different device into it and see if it works. If it doesn't - you'll need to inspect the fuse or wiring. (you could also try the charger in a different port or different car to see if the issue is tied to the charger).
If the other device does work, it is possible that the charger has a built in fuse. If the charger is the type that plugs into your cigar lighter, you may find the the tip holds the fuse. The tip may reveal the fuse if unscrewed from the body or may require a screw driver to open the body. Either way, you'll need to ascertain if there is a fuse in it and if so, check its condition.
Sometimes, the charger needs to be aligned a certain way in the cigar lighter / power port (or outlet) due to the way some automakers and device manufacturers design the connections. Repeatedly remove and replace the plug in the lighter / port. Each time, turn the the plug slightly so that it takes 6 to 8 insertions to rotate all the way around in the outlet. This should provide at least one position that allows the plug to make the required contact in the lighter / power port.
Lastly, make sure that there is no foreign object / debris in the outlet, that the the plug fits snugly in the outlet, the the plug's tip has a spring pushing it forward and that the plug is fully inserted into the outlet.
Hopefully, one of these suggestions will get it working. Good luck!
Mar 21, 2012 | Navman S30 Car GPS Receiver
Hi, i had a flat battery and took it off to charge it up,i came to put it back on but realized i had no key to get in the boot and obviously have no power and my car is now stranded on my drive going...
Go to any Automotive Parts Supplier (Advance Auto Parts) and tell them that you want a 9 volt battery backup that plugs into the cigarette lighter.......Or if you have a jump box,you with a 12 volt outlet plug on it,buy the cord that connects the outlet plug on jump box to the cigarette lighter outlet plug in the car.......Either option will give you the juice that you need.....I just hope that your boot is electronically operated
Mar 28, 2011 | 2000 Mercedes-Benz CLK
My charger is no longer charging my iphone which has not changed. The red light does not come on when I plug the charger into my car.
The first thing to do is make sure the problem isn't with the outlet your using. Try another outlet, preferably one in another car just to make sure the problem isn't a fuse or the contact points in your outlet. Try another device into that same outlet and see if it works.
Feb 27, 2011 | Just Wireless Swivel Vehicle Charger
My power cord that plugs into car outlet was lost. I purchased a universal plug in. When it is plugged into the car outlet it shows a garmin display and a picture of a computer with a cord going to the...
It could be a problem with the mini USB plug on the charger. If it doesn't go in far enough it will cause that problem. Try pushing it in further. If that doesn't work you'll need to get a Garmin power cord.
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
My cigarette lighter is not charging in my car what could it be?
You mean there seems to be no power to the vehicle's lighter unit outlet.
This lighter unit outlet is normally wired through its own fuse so check the fuse panel in the car for a blown fuse. If blown it must be replaced with a fuse of the correct amperage. The owner's manual will show you where the fuse is located.
Before you check the fuse just check the cigarette lighter outlet with another plug-in device if you have one such as a portable 12 volt tire compressor or a 12 volt plug-in auxiliary light. It could be that if you are using a charger from the outlet, the charger plug or wiring may be faulty rather than the car's power outlet itself. (These outlets don't usually give trouble unless the wiring has been messed with or the outlet itself has been damaged or abused).
If no device works from the lighter power outlet check the fuse as it may be blown.
Sean
Voluntary contributor.
Dec 27, 2009 | 2006 Ford Taurus
Garnin NUVI 680
Needed to change the fuse
Aug 08, 2008 | Garmin Nuvi 660 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
132 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
