Question about Samsung ML 2010 Laser Printer
I can't turn toner save mode off!
The toner save mode is currently activated on my printer and I don't know how to switch it off - does anyone know?
  • Anonymous Oct 18, 2008
    I can't turn toner save mode off!What button?
You need to press the button for about 1 or 2 seconds then let go. If you don't press it long enough it doesn't work, same if you press it for too long.
Posted on Oct 29, 2008
Answer was great but it could be clarified by stating that it's a quick press of the cancel button.
Posted on Oct 31, 2008
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Push the button))) That's so simple)))))
Posted on Oct 17, 2008
  • Ioan Yordanov
    Ioan Yordanov Sep 11, 2015
    Push the button - as a result of Push the button - printer print test page and not change mode. That is the problem
Gestetner dsm730 error code sc590
SC 590 - Toner collection motor error.Possible causes:
- toner collection motor defective
- too much load on the drive mechanism
- poor toner collection motor connector connection
- toner collection motor sensor defective.
Reset procedure:
1. Turn OFF/ON the power switch.
If the trouble don t reseting press the Clear (yellow) key press 107 press and hold last more 4 seconds the Stop/clear(red) key,enter inSP mode,then turn the main power switch OFF/ON.
Feb 04, 2013 | Gestetner DSm730 Black and White Copier
Epson C2600N waste toner collector full warning, after replacing the collector
Victor_Ott:
You have emptied the waste toner bottle, now you have to tell the printer that you have done so. The waste toner collection system has a "latch" (electrical signal) that is tripped when the bottle is full. it may be a pressure sensitive switch under the bottle or a photo-sensor that senses the toner level when full. I don't know the sequence of events to "switch" that latch. Usually on the larger machines it is a series of keystrokes on the printer's keypad, starting with turning the machine off and holding down a series of keys while turning the machine on (known as the "maintenance mode". Once you are in the maintenance mode, you can "trip" that "latch" to let the copier know that the toner collection bottle has been emptied.
Sep 22, 2012 | Epson AcuLaser C2600N Printer
Drum and toner lights are on and both have been rep[laced and page is still shadowed
Have U replaced with Original Drum & Toner.
  • Check the printer's environment. Conditions such as high humidity and high temperatures may cause faint print.
  • If the whole page is too light, Toner Save Mode may be on. Turn off Toner Save Mode in the printer Properties tab of the driver.
  • If Yes please clean the corona wire.
  • Turn off the printer power switch, and then unplug the printer.
  • Press the front cover release button and then open the front cover.
  • Take out the drum unit and toner cartridge assembly.
  • Wipe the scanner window with a dry, lint-free cloth.
  • Put the drum unit and toner cartridge assembly back in the printer.clean_inside91.gif
  • Jun 02, 2011 | Brother HL 5030 Laser Printer
    Call service 7000:0165540 FS 2000D
    Are you using manufactures toner, my guess are it is after market toner or not seated correctly, or the toner cartridge has a busted gear, either way.. try a different toner cartridge. 7000 error indicates the toner motor cant turn. the 0165540 is the page counter;
    Toner motor lock error
    A motor over-current signal is detected
    continuously for 5 seconds since the
    toner motor is activated
    ;) hope this helps
    cheers
    Nov 03, 2009 | Kyocera FS-2000D Laser Printer
    My printer shows ayellow light - toner save-and prints faint
    You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
    Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
    I have a hp laserjet 4100n and everytime i print it keep telling me that manualy feed plain letter paper but I wanted to automatically print on tray 2 which it does not, I know my settings are wrong if it...
    The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
    MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
    The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to check the paper back stop in tray 2.
    The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
    If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
    Or the arms on the tray that operate the switches are not moving properly.
    You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
    Hope this helps.
    Mar 04, 2009 | HP LaserJet 4100n Printer
    Scanned docs are too light
    Hi.
    On some printers there is a "save" mode with the purpose of saving
    ink or toner that if "on" will result in light printing.
    Also see to that the scanner is scanning it with the right light/dark setting so that you know the picture has correct darkness and contrast to start with.
    Hope this will help you.
    Have a great day..
    /Tech5508
    Jan 28, 2009 | HP LaserJet 3050 All-In-One Printer
    Samsung ML 1740 Printing Very Light
    If the entire page is light, the print resolution setting is too light or Toner Save Mode is on. Adjust the print resolution and Toner Save Mode in the printer properties.
    Make sure TONER SAVE MODE is NOT ENABLED!
    Sep 05, 2008 | Office Equipment & Supplies
    Toner Saver.
    Using the Toner Save Mode
    The Toner Save mode allows the printer to use less toner on
    each page. Selecting this option will extend the life of your toner
    cartridge and reduce your cost per page, but will reduce print
    quality.
    There are two ways to enable the Toner Save mode:
    From the Control Panel
    Press the Cancel button on the control panel. The printer must
    be in Ready mode (On Line/Error green LED is on).
    • If the Toner Save LED is on, the mode is enabled and the
    printer uses less toner to print a page.
    • If the Toner Save LED is off, the mode is disabled and the
    printer prints in the normal mode.
    From the Printer Properties
    You can also enable the Toner Save mode in the Graphic tab of
    the printer properties. For details, see Software User’s Guide.
    Jun 30, 2008 | Samsung ML 2010 Laser Printer
    Canon ir1510 blank copy problem, and always showing toner level low indication... but toner and drum is new... whats a solution.. pls any one tel me..
    check the hopper motor of the machine. the motor near behind the toner. check if it turns. open the front cover. check the cover for switch activation. activate the switch and make a copy if the toner bottle turns the hopper motor is ok.
    Mar 19, 2008 | Office Equipment & Supplies
    Samsung ML 2010 Laser Printer Logo
    1,933 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
