Gestetner 3245 (used toner case nearly full)
Used toner case nearly full.. wer it is located how can i fix it??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Most likely it will be on the right rear. look for a door w/ a couple of screws, there is a white plastic container, empty or replace and put back. should clear on it own when done.
Posted on Sep 26, 2008
Where is the waste toner bottle for the Gestetner dsc 535
It is located on the lefthand side of the machine under the yellow pcu unit. You will have to remove a cover next to paper tray 1
Mar 16, 2010 | Gestetner Copier
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
I have a Gestetner 3245 With Code SC 322-00 call for service message on. What is it, can it be fixed or reset. I bought it used to use in my classroom. Thanks
Hello sir; The error code you display on screen, it means laser unit have problem, it can not be reset but it can be fixed, you have to call your local technician to help you.
Oct 13, 2009 | Gestetner Office Equipment & Supplies
My Gestetner 3235 will no longer work.
Open the duplexer, open right door the brown belt thing is the transfer and waste toner assy, on the front side of this is a 1.5 inch handle that needs to be lifted to the upright position and rock it away from the copier and place it on newspaper, take the 2 springs off lift the brown belt upper portion up releasing the tab on the front side. now you need to "dump" all the waste toner from the lower half. and reassemble, rember to put it back like it was.
-Carl, please let me know if this helps.
Jun 18, 2009 | Gestetner DSc224 Copier
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Gestetner 3245 used toner case
try http://www.precisionroller.com/
Order using the Ricoh equivalent model number which is: af450.
Sep 26, 2008 | Office Equipment & Supplies
Gestetner 3245 error
Your machine must be serviced by a trained technician. Cleaning out the used toner requires disassembly and specialized knowledge and equipment. If you keep using the machine, it will stop working completely when the used toner is full, and will not be usable until the used toner is cleaned out.
106 people viewed this question
jasbo
jasbo
