Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Wireless router problem
I have a Linksys wrt54g v2.2 wireless router, and i cant get the wireless to go, it used to work we had a dlink modem. But that died now we have a speed touch modem and its never worked with it... I tried the smple things. but i just dont know enough about them to fix them.
  • Troy Scott
    Troy Scott May 11, 2010
    What do you have it connected to? cable modem? Have you tried resetting the router?
  • D-Link Master
  • 6,487 Answers
Try first to reset the router , since your have a new modem the router should be configure first to work with it, so after resetting the router now just run the setup CD of the router to configure it to work with the new modem that you have.............
Posted on Nov 07, 2008
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Upgraded dsl modem to westell G-90-610015-20 and my linksys WRT54G router cant get an IP address. I just upgraded the modem from and older westell model, didn't change any of the settings and it can't get...
if you connect the computer directly to the modem, without any router , does it work?
Make sure that your computer will be online when connected to the modem.
If you are not online through the modem, then you should have the correct user name and password for the ISP.
Click Here for step by step solution
Oct 30, 2009 | Linksys Wireless-G WRT54G Router
My Linksys WRT54G Will Not Work.
It seems that your cabling is wrong. This is what it should look like:
  1. Telephone outlet to cable modem (Via telephone cable)
  2. Cable modem to router (via Ethernet cable)
  3. router via Ethernet cable or wireless to computers
Does your setup look like this? Please let me know if not so we can configure it correctly.
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
Need settings for Huawei HG510 with Linksys wireless WRT54G
You could reset you router to default settings.
On the back of you router, you will find a little hole
using a pen, press that reset button.
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
Need to redo wireless setup betw linksys & westell
You will need to assign a different ip address to the Westell modem - I am assuming that both the router & modem are using the same ip address If that is the case, then assign to the modem.
Mar 15, 2009 | Linksys Wireless-G WRT54G Router
WRP 400 Inbound call issue
This could be due to the fact the when using multiple routers you need to let the main router know the routes into the second router.
I do have a question as to why you would use the second router and not the dlink?
I would suggest dropping the dlink router/modem and get your ISP to send you just a modem and then use the linksys. Or of course don't use the linksys and just use the dlink.
Oct 03, 2008 | Linksys Wireless-G WRP200 Router
your starband is if im right the cable modem ? connect the modem to the router and then the router to the computer ? then run the linksys easy connect @
Jul 19, 2008 | Linksys Wireless-G WRT54G Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
32 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
