Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model HSS25IFMDWW "bottom" Fan is not operating.
I think it's called the evaporator fan, but not sure about that. It's the fan that's down on the bottom in the back, it cools the cylindrical coils down there.
Well, it's not operating. It gets cool in the freezer and coolish in the fridge, but obviously it's not operating correctly. I first noticed something was seriously amiss when the ice cubes were melting down the front and my ice cream was liquid.
I know it's not the fan motor itself that's bad. Because I've replaced it. I wish I had typed this before dropping the $40 for a new one.
I'm assuming it's thermostatically controlled, and it's a sensor thats gone out. What would really be helpful here is a schematic or someone that "knows something" about the sensors in this specific model.
I'm hoping against hope that it's not the main board, since that's gonna cost me around $90 or more. Please, can't it just be a really simple to get to sensor that I can buy for five bucks and plug the ****** in? heh. Fat chance, right?
It's about five years old.
Model Number, again:
HSS25IFMDWW
  • psycholabs Sep 27, 2008
    Some more information:
    I did check the Voltage coming out of the fridge to the fan socket before going ahead and buying another fan. It came out to around 13v DC, which I found fascinating considering the fan has on it the spec "11.3V", "1.9W".
    Of course, not having any clue as to exactly which wire was supposed to be ground and the other ones hot or what, I figured it was pumping out the voltage and it was worth the money to get the fan.
    I was wrong :)
    Maybe I could whip up a little DC power supply and hook it up to the motor separately just to make the thing work. (that's about half joke.)
    I would just do that and run it but I'm afraid there's something else the matter and doing that is only going to make things worse, read: more expensive, down the road. Right now it's off and I'm living off frozen things that I can keep in the chest freezer downstairs.
  • 58 Answers
You are correct in assuming that it is the evap fan. its purpose is to dissipate heat captured from the freon as it leaves the compressor. it could be that your defrost timer is faulty, but very hard to diagnose online.
Posted on Sep 26, 2008
Can you tell me why my ice ain't freezing but everything else is
Its possible to freeze item below the evaporator, but with out a fan moving air the ice must be located above the evaporator. I hope this helps and answers your question. I would look for a fan issue, or get me a model number and its possible I can assist you further if needed. Thanks
Apr 16, 2016 | Refrigerators
Water Freezing Under Evaporator Fan
Check this site for more info on where the defrost timer might be.
May 05, 2008 | GE PTC22SBMR Top Freezer Refrigerator
Subzero 501R fan won't shut down when door closes
HI, I'll be able to help you out but I want to go over some stuff that way you'll have a better understanding of your machine so if I have a question it will easier for you to answer. Lets start out with the fan. The fan your hearing inside the machine is called an evaporator fan. Its located at the top of the machine directly over the evaporator coils, which are behind the back wall, that freon goes through in its gas state to cool the machine. The evaporator coild get cold and the fans job is to pull air from the bottom of the machine, across the coils and intio the refrigerator itself and therefor cooling the whole thing. The fan does not extract air out at all. The suction sound you hear is caused from the machine design and the differential in temperature in and out of the machine. The fan will runs non-stop with only 2 exceptions. First being the door getting opened, which opens the switch, I think on that model is located naer the bottom next to the light switch. If the fan is running after you open the door your door switch is stuck or broken and needs to be fixed, but that wouldnt' tmake the temp raise. The second is when the thermostat registers that its cold enough it shuts the fan off. From the age and what your saying is going on I would first check the condersor coils, located behind the removable grate and see if they are really dirty. That would cause the temp to raise airfloe is blocked and the compressor gets too hot. While down there check the fan to see if its running as that too will cause the machine to get hot if not. Ihe coils are clean and the fan is running call a tech because you probably have a freon leak, which is the likely candidate.
May 03, 2012 | Refrigerators
Model HSS25IFMDWW The freezer has stopped cooling and I asume the fridge will shortly as well? What is the typical problem to look for?
Can you hear the compressor running? Pull the unit out from the wall and see if you can hear it and also look at the evaporator fan to see if it is running. Post back your findings.
Jul 21, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Maytag 27.3 cu ft model #MSD2756GEW freezer freezing refrigerator side not cooling
Check the air damper if it opens as you adjust the temperature control. If yes then check the freezer fan motor. First, disconnect the unit from the power source then remove the freezer shelving.
Loosen the two top screws and remove the two bottom evaporator cover mounting screws then grasp the bottom of the cover then carefully pull it forward and down to clear the upper flange.
Disconnect the evaporator fan motor leads. The wire leads are self-locking and it is important to squeeze the clip before pulling the leads off the terminals.
Remove the evaporator fan motor assembly and place it on a work surface. Connect the motor terminals to a service cord and plug the cord into the 120 VAC power source. If the motor fails to operate, it is defective and must be replaced.
Here's the service manual for further troubleshooting.
Jul 06, 2010 | Refrigerators
Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Nov 06, 2008 | Kenmore Refrigerators
Kenmore model 59675502400
if the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
drcool
Aug 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Hello, I have a side-by-side Samsung Refrig from Costco. I freezer started to ice up today. I removed the ice maker compartment and took some of hte freezer items out to provide more room for the air to...
the evaporator fan motor will not run when you have the door open - you have to press the door switch in to make it run.
But if you are doing this and the fan is still not running then this explains the evaporator ice up problem.
You will have to take it apart (make sure that the power is off) and just unplug the evap fan (usually just plugged in)
Usually these fans are a standard type of fan and you will be able to get one from a electical wholesaler or just call samsung and get one from them - make sure you have the model number with you when you order it though.
Apr 09, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
174 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
