Question about OKI Office Equipment & Supplies
Removed the bar where the thickness sensor is to clean the rollers and now it is saying ’323 thick paper senor error’ when there isn't any paper
Took off the sensor bar and thoroughly cleaned it and replaced it. It seems ok now
Posted on Sep 26, 2008
THE MACHINE INDICATE J11 WHAT IS THE PROBLEM
j11 indicates that the paper is not being fed from the paper cassette 2.
This can be caused by incorrectly loaded/thick paper. Cassette not correctly adjusted.
Paper feed rollers need to be cleaned or replaced. Blockage or parts failure.
Mar 24, 2014 | Kyocera Copystar CS-1635 Copier
Error 13.33.00 hp 4345
Paper jam inside top cover area. The paper didn't arrive at the paper-delivery sensor on time. This is usually due to worn out paper pick and feed rollers in the paper trays. Replace the rollers and you should be good. This error also occurs if your paper has a high moisture content, is the wrong kind of paper (too thick or too thin), or is loaded in the paper cassette incorrectly.
Mar 12, 2014 | HP LaserJet 4345mfp Printer
13.33 = Paper jam inside top cover area. The paper didn't arrive at the paper-delivery sensor on time. This is usually due to worn out paper pick and feed rollers in the paper trays. Replace the rollers and you should be good. This error also occurs if your paper has a high moisture content, is the wrong kind of paper (too thick or too thin), or is loaded in the paper cassette incorrectly.
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Canon ImageRunner 2800 toner buildup
YES this parts is for cleaning purposes to collect toner that was building on the pressure roller .replacement of this assembly is needed if thick toner waste accumulates on the roller
Jul 16, 2009 | Canon Office Equipment & Supplies
Get paper path error when path is clear & clean.
There are two types of sensors, optical and mechanical. Sometimes the mechanical sensor get stuck and give a message to the scanner that paper still remains inside the scanner. Check if any of them is stuck, Blow air from a dsiatance so that any shreds of paper is foreced out.
S. Mohan, India
Jun 22, 2009 | Bell & Howell Sidekick 1400 Path-Through...
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
Magicolor no longer grabs thicker papers
I think you need to clean take up roller first, and then set the settings in printer propertis in thick paper.
shold work.
cleaning:
open cover, remove imagine unit, then you can see the take up roller. clean it.
Dec 25, 2007 | Konica Minolta magicolor 2400 Laser...
97 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
