Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Warming up non-stop with this message UF-585 (YM) OPT
The machine keep on warming up with the above message displayed on the panel.
    Genius:
  • 2,120 Answers
Open top cover
remove toner cart.
leave cover open
Press:
Function
7
monitor key slowly 4 times
6
scroll down to "all job clear"
(as a last resort choose "shipment set")[sets machine to factory default]
wait for machine to reboot
Posted on Sep 26, 2008
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
Feb 03, 2011 | Panasonic Panafax UF-585 Plain Paper Laser...
Where is the battary place?
On top of the operation panel by the blue slider knob
Jun 19, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Where is the battery
The battery is above the display, next to a sliding blue lever.
Open the toner door, pull up the panel about 1 inch. Pull out the holder.
May 31, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax UF-8000 not responding, energy saver light flashing.
It sounds like the operation panel is bad or has a loose plug.
Remove left and right top screws that hold the left and right panels on.
Wiggle the op panel towards you and up, check the white wire harness.
Good Luck!
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
6
scroll down to SHIPMENT SET
set
set
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
UF 585 Fax Machine Message in memory
if its only a few % like 1, 2, or some thing its probably nothin retrievable, you can have a tech come and clear it but if all else is working and the mssage in mem file dosent keep growing try and ignore it till next service
May 05, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Warming up message
how long have you had this machine?
May 23, 2007 | Brother IntelliFax-2820 Laser Fax
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
143 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
