Question about Sony Ericsson K550i Cellular Phone
Screen saver how can i get my name on my mobile screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
You can do it by going to your phone's "Picture Editor" then select type: "Black&white" or "Colored", (it's on you) press "Tool" then "Select Tool", and select/click "Text",move the joystick on where u want the text should be located then press. Type ur Name or any text,press joystick once then select "More" then "Save Picture" or just save it directly. Go to "My pictures" or to the folder where u saved it, and set it as "Screensaver" ....that's it, you have your name as your screen saver now. Ask me if you need more help and clafrification about this....hope to hear from u soon! A rate from you will be much appreciated. Tnx!
Posted on Sep 26, 2008
How do you download a screensaver of your choice to the phone from a computer?
......downlaod screen saver files for ur respective mobile phone set and copy them to the memory card.... from mobile go to details>>>use as>>>>screen saver
Feb 08, 2010 | Sony Ericsson W200i Cellular Phone
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Toshiba L10 display will not work.have pressedfn+f1 and fn+f5 but to no avail.
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?). 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 22, 2010 | Toshiba Satellite L10 Notebook
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
How do I get rid of screen savers I have one with underwater,fish swimming,bubbles and behind that one I have a Halloween on with a black cat, bats,etc.
If your are running Windows XP you have have several options. USE OPTION 3 ONLY if you are comfortable working with system files and as a last resort.
  1. Open your "control panel" > "Display". This will open your "Display Properties" window. Click the screen saver tab and set your screen saver to "[None]" This setting will not put your monitor into any screen saver mode.
  2. Open your "control panel" > "add or remove programs" usually a downloaded screen saver will appear in this list, find the appropriate file/screen saver you wish to remove & click remove. If you wish to permanently remove the screen savers.
  3. I strongly suggest you do full back up of your system or at minimum create a "Restore Point" BEFORE you do any of the following suggestions!!! You could also search for the screen saver files. Click "Start" > "Search" This will open the "Search Results" Dialog window. look in your local hard drive where XP OS is installed. This usually is your c: drive. In the "All or part of the file name:" box enter "*.scr" this will give you a list of screen savers in your "C:\WINDOWS\system32" folder. Be VERY CAREFUL working in this file!!!! If you delete the wrong file your OS System may quit working properly or altogether! I am not sure if a downloaded screen saver has the file extension ".scr", I think they do. Maybe someone else could clarify that for both of us.
GOOD LUCK!!!
Oct 18, 2009 | HP Computers & Internet
Can you have a screen saver on the samsung tocco and if you can how
Unfortunately they have not provided the screen saver option. Even I was very eager to see a screen saver on my F480 mobile.
Aug 23, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Screen saver of Samsung M620
The device will only allow you to set certain defaults as far as your background theme and screen-saver. Go to "settings", then "display" and you will should see "screen-saver/and or "background". Once you access this application, it will give you a default list of changing your screen-saver/background for your preference.
Mar 13, 2009 | Samsung UpStage SPH-m620 Cellular Phone
Removing Screen Saver name from Screen saver list
Right click on the desktop, select properties on the menu, then the screensaver tab to view what options you have. Vista is a royal pain with regards to whether you are in the administrator mode. Right click on the task you wish to execute and select 'run as administrator' menu option.
Nov 07, 2008 | Microsoft Windows Vista Ultimate Edition
NO screen saver on
run "regedit" and go to
HKEY_CURRENT_USER\ Software\Microsoft\Windows\ CurrentVersion\Policies\System
delete the one with the name ""NoDispScrSavPage"
BEST REGARDS FROM
AHMAD RABBANI
FORMANITES
Oct 02, 2008 | HP Pavilion dv6000z Notebook
Error message
N~ 1.SCR looks like a truncaked screen saver name (when a name is longer then 8 characters, it comes up with the ~) the .scr is a screen saver extension.
Just as something to try, disable any and all screen savers you have running and see it the error stops.
Please inform after trying this.
Jul 20, 2008 | Acer Aspire™ T180 PC Desktop
Sony Ericsson K550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
