Question about Hayward H Series Induced Draft Abg 100,000 Heater
Hayward pool heater h series
When i turn pump on with the heater thermostat off it runs fine.when i turn the thermostat on heat it fires and starts heating.then it will start making noise like there is a rock in the system.it will quit making rock noise and then the heater will fire again....this happens over and over and over
  • jamesdob870 Apr 24, 2009
    almost the same problem...burner starts fine but goes out after short while but blower keeps running w/o reigniting burner...7 yr old took filter out to make sure water flow high no change...
  • 4 Answers
The issue is a broken baffle in the system. there is a baffel that directs water into the heat exchanger and back out into the system. The welds that hold the baffel in place have broken off. It can be repaired if you take the unit to someone with a mig welder and have them re-weld it (muffler shop, mechanic?). there needs to be a weld on both sides. You can see the baffel if you remove the unit and look down the inlet and outlet tubes.
Posted on May 25, 2009
  • app_3rp12317
    app_3rp12317 Jan 09, 2012
    I fixed mine with JB Weld - easier than removing the plastic parts for welding. It appears that was what was done at the factory, too, because there are drips unlike one would find in a weld. FWIW.
    I have re-placed this baffle where it was originally. Banging is much reduced. . . but persists. I'm quite surprised, now. Not sure what else to try.
It sounds like you do not have enough water flow through the heater. If you do not have enough water flow though the heat exchanger you will damage the heat exchanger very quickly. I'm certain this is your problem.
Posted on Jan 24, 2009
Did you find a solution ? I have the same problem
Posted on May 31, 2009
My Hayward H400 will not turn on
Does the heater sound like it is trying to fire? (Fan on, clicking sound). Check your filter pressure. If it is high, it may be causing the heater not to fire because the heater doesn't know the pump is running.
Apr 12, 2014 | Hayward H Series Pool & Spa Heater 400k...
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward H Series Induced Draft Abg 100,000 Heater Logo
1,294 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
Pj Kiley
Pj Kiley
Level 1 Expert
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
