Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba tv 42h83 projection sound no picture it is about 8 years old
SOURCE:
  • 87 Answers
SOURCE: Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Aug 02, 2007
  • 1694 Answers
SOURCE: Toshiba 42H83 rear projection tv turns on but i have no picture or sound. happened suddenly. What can troubleshoot before seeking proffessional hel.
Check all micro-fuses in power supply.If two or three are bad,a convergence circuit O/H will be necessary.Pro help usually required-chassis pull,replace convergence IC's and careful hand- soldering needed to prevent call-back.
Posted on Sep 29, 2007
  • 2920 Answers
SOURCE: Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Posted on Feb 01, 2009
  • 277 Answers
SOURCE: 65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Posted on Sep 17, 2009
SOURCE: Picture image is unsettled when
We're having what sounds like the same problem. I'm going to try an upload two photos.
SD Tech, I Googled PTS Electronics but can't find direct contact info. Also, I'm fairly handy and would loike to remove the board myselfjean_chamble.jpg
Posted on Nov 15, 2010
My toshiba 42h83 tv has sound but no picture
of course check different inputs etc to make sure something did not get disconnected.
This rear projection set uses 3 picture tubes and the set will protect them if there is a problem in the vertical or horizontal sweep circuits that might burn the screens or the damage the tubes.
No simple answer as a lot of different parts are possible for this problem.
Apr 27, 2012 | Toshiba 42H83 42" Rear Projection...
Control board say not availible when any button is pressed, only shows av1 picture and picture is scrambled, toshiba 42h83 modle rear projection tv
this may be due to a stuck on mode select button control, are you going to try to repair yourself ? do you have a shop manual ? let me know
Jan 30, 2010 | Toshiba 42H83 42" Rear Projection...
The picture is all waves ,I get sound and color but the picture is all lines and waves,what part should I get??
To fix the shaky picture on the toshiba rear projection tv model number 42h83. You need to either replace the 13 capictors on the hyper module or simply replace the hyper module itself. It's cheaper to replace the caps, but you'll need decent soldering skills to do this. You can replace the entire hyper module with less soldering skills, but I believe the module costs about $100, maybe alittle more. You can find the entire fix by googleing "hyper module". Good luck and I hope this helps
Oct 21, 2009 | Toshiba 42H83 42" Rear Projection...
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
I HAVE WAVEY LINES ON MY TOSHIBA 42H83 RP TOO!
wavey lines all over screen? does piture inmprove when it get warmer? this to me is indication of the "hypermodule signal processor" this can be fix but s a difficult repair. have to replace several VERY SMALL capacitors not a repair for novice.
Mar 15, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H82 RPTV: Sound but no picture
It sounds like the 200v supply to the crt's is missing. this is the source for driving the tubes, other than the high voltage generated by the flyback transformer. If the set got really bright gray with wome white lines that are kinda on a diagonal, this is generally the cause. the source for this voltage is a diode on the secondary of the flyback transformer.
Jul 11, 2007 | Toshiba 42H83 42" Rear Projection...
May 21, 2007 | Toshiba 42H83 42" Rear Projection...
Open Questions:
Toshiba 42H83 Hyperboard 20 minute Wavy Line Repair Snafu I have repaired several tvs, this one has been more of a challenge due to lack of only service manual without a schematic. I replaced the caps on the MVPU14 Hyper board. Those that I found bad with ESR meter. I am fairly certain I botched this the first time using surface mount capacitors and possibly shorted something out when I re-installed. The tv came up with a blinkng red power light problem where the tv would not turn on. I removed and re-worked the Hyperboard using thru-hole parts instead, much easier. I still have the blinking red power light with 1 second intervals problem. In trying to isolate the problem I was able to do the following: A) Removed various boards and powered unit up to watch for changes in operation. B) I found out with the DPC Unit (PD0077) removed and all other boards installed, I am able to have the tv respond to the remote and front panel buttons, have sound, but no picture. I was able to hear a DVD player playing in the background that I had connected. C) No Menu can be seen on the screen, the bulbs don't light at all. D) I still haven't ruled out a faulty Hyper board yet as I don't know if its operation is dependent on having the DPC unit (PD0077) installed. I have not found any signs of damaged components, so now wondering what is the next target place to look at. Notes: 1) TV was working fine with nice bright picture before I started repairing the Hyperboard, so I haven't considered convergence issues and such. 2) I have been focusing more on the theory that the first repair of Hyper board had a capacitor shorted possibly up near top of board by LX229. 3) I did check all the pico fuses I could find and none of them appear open. Since I don't have a schematic, if you suggest checking a voltage, please advise part number and pin to check. I was thinking the 5Volt line should be checked, but not sure where. I do notice a 9V signal temporarily upon power up but goes away when power light begins blinking. Thoughts?
Jun 09, 2010 | Toshiba 42H83 42" Rear Projection...
See all Toshiba 42H83 42" Rear Projection HDTV-Ready Questions
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
