Question about Sony Handycam DCR-TRV460 Digital Camcorder
Cannot record or play
When it is turned on it beeps and the displays the eject symbol and gives the code c:31:22 please HELP problem c:31:22
  • 4,234 Answers
The C31:22 message indicates that one of the motors inside has failed to turn. This is a safety message and the unit will eject the tape to prevent the tape from getting damaged. Unfortunately, there is little that you can do other than get the unit into a service shop. The repair of this will require dis-assembly of the unit. I would suggest that you either get an estimate for the repair or send the unit to Sony using one of their fixed rate repair options.
Dan
Posted on Sep 26, 2008
Hi my sony CCD-TRV57E keeps ejecting the tape, and
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
May 15, 2010 | Canon ZR80 Mini DV Digital Camcorder
Constant ejecting
This is already an issue with the hardware. There is a rubber bond inside the cassette that is no longer intact and needs to be replaced. Possible cause by repetition of single and old cassette tape and improper tape position.
Apr 06, 2010 | Video Cameras
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
One tel magma 300 - can't change message on answerphone
1) Press the 'tape' symbol to access the answering machine mode.
2) Press 9 then 1 for 'answer and record'.
3) Whe you hear a 'beep' speak your message. Whilst recording the display shows REC OGM1 or REC OGM2
4) Press 5 to stop recording. Your message is played back to you
5) Press 'tape' symbol to exit.
To check your Out Going Message (OGM)
1) Press 'tape' symbol
2) Press 6 then 2 and the message is played back.
Jan 26, 2009 | GE 29888GE1 Digital Answering Machine
D-eject problem
try cleaning tape? maybe tape path is outta balance. try new tape?
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
C:31:23 help me please!
If u look in ur manual it tells u that its a self-diagnosis code!
Step 1: eject the casset and then put it back in record something
step 2:disconnect the power cord of the AC adapror or remove the battery.
step 3: reconect the power or battry and record
step 4: Replace the casset!
thats a breakdown of the manuals instructions
hope this helps
ilewis
Nov 27, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
158 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
