Question about Sony VPL-ES4 Projector
Vpl-es4 sony projector-frequency out of range
  • 4 more comments
  • Anonymous Oct 20, 2008
    I have the same problem please helpppppp
  • Anonymous Oct 23, 2008
  • Anonymous Oct 31, 2008
    I have same problem
  • cap4 Nov 16, 2008
    Same issue, I have tried several different possible solutions without success. Very frustrating. If someone has a solution I would appreciate it.
    Thanks....Joe C.
    jczentnar@snet.net
  • abbeypazhoor Nov 30, 2008
    my sony projector showing frequency out of range
  • Anonymous Dec 04, 2008
    works on my PC but not others
Change the screen resolution to 600x800,and switch to other monitor by hitting fn+F6 key (Laptop).if the screen get black use alt+Ctrl+F3 to switch it on .
thanks
Hussam
Posted on Dec 15, 2008
    Scholar:
  • 168 Answers
I need more information regarding what kind of machine did you hook up on that projector. whether its a VCR, CD/DVD, or computer? try to check first whether your cable connecting to the projector is fine or did you hook it up in the correct manner. like video supposed to go to video. things like that. good luck
Posted on Nov 10, 2008
Pl. send me solution. I am stuck with problem
vpl-es4 sony projector-frequency out of range.
2 Suggested Answers
  • 4 Answers
SOURCE: HOW TO SOLVE FREQUENCY OUT OF RANGE IN SONY LCD
get a life u fool
Posted on Dec 24, 2009
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
Jun 23, 2015 | Sony VPL-ES4 Projector
Frequency is out of range
What are you sending to the projector? The ES4 is a native S-VGA resolution machine. This means it has a 4:3 display panel with a pixel count of 800x600. It will accept higher resolutions, but there may be some combinations that are 16:9/16:10 that the projector isn't happy with; specifically 1080p @ 24/50/60Hz. It maxes out at 1080i 60Hz. So if you are connecting a laptop with a native resolution of 1920x1080 then the projector will struggle.
The other thing you should do once you get a signal working on the projector is to set the laptop output to the projector's native resolution. This will give the crispest image.
Toggle the laptop display (Fn + appropriate F key) so that laptop screen is off and the projector is the only thing getting a signal. Then right click on the Windows desktop area, and then select Graphics Properties from the sub menu. Change the settings from there.
Sep 08, 2014 | Sony VPL-ES4 Projector
Toggle the laptop display (Fn + appropriate F key) so that laptop screen is off and the projector is the only thing getting a signal. Then right click on the Windows desktop area, and then select Graphics Properties from the sub menu. Change the settings from there..
I have a Sony projector VPL-ES4 and the ON / Standby red flashes 6 flashes. I got the lamp, I cleaned the air filter, I tried to reset Left Right Enter key and the problem still persists. Can you help?...
check a small bord under the mother bord calld air sensor
its look`s like a transistor check the divice properly and change the projector frimware through computer
Aug 16, 2012 | Sony VPL-ES4 Projector
"Frequency is out of range"
Most likely your PC or laptop is currently set to a display resolution that is too high for the projector or is one that it cannot handle. Try setting your computer display to 640 x 480 or 800 x 600 and see if you can get the projector to work. If it does, then you can figure out the maximum display resolution you can use. Also consult your projector documentation for supported resolution modes.
Jun 21, 2011 | Sony VPL-ES4 Projector
Frequency out of range
change the frequency to low one
Nov 06, 2010 | Sony VPL-ES4 Projector
How to rest lamp timer vpl-es4 - reset < > enter - doesn't seem to work
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
Apr 06, 2010 | Sony VPL-ES4 Projector
Sony VPL-ES4 Projector Logo
3,662 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
