Question about Dell OptiPlex GX520 PC Desktop
System hangs at screensaver at dell desktop 745
System hangs every time the screen saver i s loaded. I've tried " Last Known Good Configuration", system restore, update display driver, install system software. what can be the solution for this problem?
  • bobbabu01 Sep 26, 2008
    hi kiran,
    I've tried to view mscofig file, can view
    but when i type prefecth at run, it says incorrect name. Please reply
  • 94 Answers
Well try this
- > disabling startup programmes but not un-installing : Start -> Run -> type msconfig & press enter -> select startup tab on the top -> click on disable all. Apply & OK... computer restarts...
-> delete prefetch : Start -> RUN -> type prefecth & press enter -> in the window select all and shift delete.
then try performing disk cleanup ...
Posted on Sep 26, 2008
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Windows start up screen keeps replaying on screen and never loads
This is a very short description without much detail, but you have a corrupted driver that loads, fails and causes the system to reboot.
Try tapping F8 while booting up and starting until you get to a menu list.
Try "restoring" if you can get to "Safe Mode" to last known good configuration
Mar 27, 2010 | Dell OptiPlex GX260 PC Desktop
Tried to install a used 20gb working hard drive
I think that you have to reinstall the XP os on the hard drive again.
Nov 30, 2009 | Dell Optiplex GX60 PC Desktop
No screensaver or power mangement
Hi there.
Right click on the desktop and select properties, then select the screen saver tab, you can set screen saver from there, select a screen saver and set the time you want it to activate.
Remember that the screen saver will not work unless you leave the computer to idle.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | Dell Inspiron 530 PC Desktop
Gateway 420GR will not boot up
Try hit F8 before gateway screen start last known. Start the computer using the last known good configuration
  1. When you see the message Please select the operating system to start, press F8.
  2. Use the arrow keys to highlight Last Known Good Configuration, and then press ENTER.
  3. If you have a dual-boot or multiple-boot system, choose the installation that you need to access using the arrow keys, and then press ENTER.
note.gif Notes
  • Choosing Last Known Good Configuration provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. It does not solve problems caused by corrupted or missing drivers or files.
  • When you choose Last Known Good Configuration, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
  • NUM LOCK must be off before the arrow keys on the numeric keypad will function.
If this doesn't work you go into setup and make sure your system is finding your hard drive or you will have to find your restore disk. mysleuth
Apr 02, 2009 | Dell Dimension 8200 PC Desktop
My pc keeps on restarting.
Tap the F8 key when booting up. This brings you to a screen with different options. Choose Use last known good configuration. this should solve the problem. Your system is stuck in a loop.
Please don't forget to rate me.
Feb 02, 2009 | Dell OptiPlex GX280 PC Desktop
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
System won't log on
try safe mode. If it works, use system restore to go back to a previous working configuration. If safe mode does not work, try the last known-good configuration. Restart the computer, then as soon as the Dell logo shows up on the screen, press the F8 key repeatedly until you enter the Advanced Options Menu. Use the arrow keys to select Last Known-Good Configuration, then press Enter.
Jan 11, 2009 | Dell Inspiron 1150 Notebook
A blue screen appears in the place of my screensaver.
i) whenever u keep ur system idle for few minutes or longer time ur system goes in screen saver mode, in order to know more about it......
Screen Saver Mode: when u keep ur system idle for few minutes(say more 10 min or any or u might u kept system idle while you some work to doo...) in such a case u will have graphical picture of a blue screen evolved on your screen, you can even changethe picture or screen saver and keep your own.....
right click on desktop(close all the windows) and select the button Screen Saver and configure to apply your own screen saver(try to explore and learn about it....
Thankin you
M. Sridhar
Dec 31, 2008 | Dell Precision Workstation 470 (204816690)...
Screen saver
I have some links below that will help you sort ya problem. have a look at the last one first ... :) screensaver-loading start-automatically-ftopict9776.html
Sep 06, 2007 | Computers & Internet
Dell OptiPlex GX520 PC Desktop Logo
145 people viewed this question
Alun Cox
