Question about Microsoft Windows Vista Ultimate Edition
No audio output device is installed
Whenever I try to play a CD on my system the video appears but the sound is not heard. The troubleshoooter tells that no audio output software is installed on this systam. So I would like to know that how to solve this problem ?
  • Anonymous Sep 26, 2008
    when ever i try to play audio files an error appears (unable to play back no sound device detacted on your system. the movie will play but you will not hear any sound.) but i have installed audio driver several times. i am using ms vista service pack 3.
  • 38 Answers
Dear prakharsriva,
It shows that your audio driver is not installed. install the audio driver from the cd that is given with your motherboard that is compatiblw with your OS.
thanks,
Posted on Sep 26, 2008
Whenever i try to play a sound or song it tells me "Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your...
There is problem with your sound card.For this
Pls enable the sound device from System BIOS ,for this re-start the system and press Del. or F2 button on POST .After that select sound controller and select enable mode.After that login through administrator and install the compatible sound driver from the Motherboard CD of from internet .
Nov 17, 2009 | Computers & Internet
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
System did't found audio driver
my sound is not installed and i no have suporrt sound drive
Feb 01, 2009 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
FDISK my drive and re-installed Win XP. I have no sound.
try the following steps. 1. Right click My Computer Icon and select properties then select Hardware tab. 2. After selecting hardware tab click Device Manager button. 3. After clicking it list down all devices that you have and expand the  "Sound Video and Game Controller" by click the clicking the plus(+) sign and it shown you the list sound devices. 4. In the list, look for explanation point(!) in yellow color beside device name (this means that device driver is missing or not properly installed) 5. Select the device name and press right click and choose uninstall. 6. After uninstallation click Action Menu and select "Scan for Hardware Changes" (this will scan the other device which is not yet installed in the system) 7. System will prompt you to load the Audio driver(insert the Audio device cd driver) if your using a built-in audio use your desktop/laptop device driver cd and locate the driver folder from cd and choose sound or audio folder the list and select the proper windows for your computer. 8. after running installation the volume bar should appear  in the right side of your desktop allong with computer date & time. if not restart your computer.
Nov 20, 2008 | Microsoft Windows Vista Ultimate Edition
Audio CD sound Prob
Various conditions may cause this problem. To troubleshoot, check the following:Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
Joystick port is not working
The audio card joystick port conflicts with another joystick port in the system. Disable the audio card joystick port, and use the system’s joystick port.
The joystick drivers, MSJSTICK.DRV and VJOYD.VXD, may not be installed. Uninstall the joystick, then reinstall to load the drivers. The drivers should come with the driver CD or floppy diskette with your sound card.
Computer hangs or restarts during installation
A hardware conflict may cause the computer to hang or restart during the installation procedure. Check the following to resolve the conflict:
A hardware conflict with another device in your system.
Previously installed sound card hardware or software needs to be removed.
The audio card is not seated in the slot properly.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices.
Resolving hardware conflicts
Hardware conflicts occur when two or more devices contend for the same resources. Conflicts between your audio card and another device may occur regarding the I/O address, IRQ line, or DMA channel:
Right-click the My Computer icon on your desktop, and select Properties. The System Properties dialog appears.
Click the Device Manager tab. In the Device Manager, a plus sign(+) represents an expandable list of items. A minus sign (-) represents an expanded list. A circled exclamation mark denotes a conflict.
Double-click Sound, video, game controllers. A list of multimedia devices appears.
Select your audio card.
Choose the Propertis button.
Click the Resources tab.
Uncheck the Use automatic settings option.
Change "Settings based on:" if alternate settings are available.
Determine the conflict by reviewing the "Conflicting device list".
Select the conflicting item in the "Resource Settings" list.
Click the Change Settings button.
Use the mouse to select a new setting.
Select OK to close each of the properties windows, and restart your computer.
Audio card is not automatically detected
To manually configure your audio card for Windows 95/98:
Click "Start" on the taskbar, and select Settings from the Start menu.
Select Control Panel. The Control Panel group appears.
Double-click the Add New Hardware icon. The Add New Hardware Wizard dialog appears.
Select Next to continue.
Choose Yes to have Windows search for new hardware, then select Next
Select Finish, and follow the prompts to complete the new hardware installation.
CD does not automatically run when you insert it in the drive
To enable the "Audio insert notification" feature:
Click the Device Manager tab. A list of devices appears.
Double-click CD-ROM, and select your CD-ROM drive.
Choose the Properties button. The CD-ROM drive properties dialog appears.
Choose the Settings tab.
Click the "Auto insert notification" option to enable.
Select OK until all Properties dialogs are closed, and restart Windows for the changes to take effect.
No sound is heard from speakers
Verify the following:
Check the Microsoft Volume Control or the Audio Mixer Program mute options and volume sliders.
Check the volume control and power connection of the speakers, if they are amplified. (Refer to the speakers documentation for detailed information).
Ensure a hardware conflict does not exist between your audio card and another device in your system.
PCI bus mastering devices may be interfering with the operation of the audio card. Temporarily remove non-essential PCI bus mastering devices. If the device is a display card, upgrade the display card drivers, or set the card to the default Windows VGA mode.
If you are experiencing no sound only during audio CD playback, see "No sound is heard from audio (music) CDs" above.
Static sounds are heard in wave files
Check to see if the static sounds are heard in all wave files. If the difficulty occurs only with certain games, refer to the software manufacturer’s documentation. To troubleshoot static sounds heard in all wave files:
Try different resource settings for the audio card, or set the card to use low DMA.
Move the audio card to another PCI slot. Feedback from the power supply or another device may be responsible.
Oct 19, 2008 | Computers & Internet
How do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Sound device
reformat & repair your OS & setup
Apr 14, 2008 | Microsoft Windows Vista Ultimate Edition
NO AUDIO OUTPUT DEVICE IS INSTALLED
windows key + R = open : devmgmt.msc
Sounds, video and game controlers > (right click) Realtek high definition audio > update driver sofware > browse my computer for driver software > let me pick from a list...> double click on Realtek high definition audio > YES to update driver warning > AND SWEET SOUND IS AUDIBLE :D
Dec 14, 2007 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
