Question about EliteGroup GF7050VT-M Motherboard
Checked jumpers all correct on board but no power to USB items like mouse and keyboard
I just installed the motherboard into an older, very slow Dell Dimension 1100 series computer and purchased a new more powerful power source at 400 watts. The screen comes up to the welcome screen on Win XP welcome screen, but I cannot move the mouse or use the keyboard.
  • eatbroccoli Sep 27, 2008
    Thanks it seems to be working fine now. But I am not sure if the USB slots are working. Would you recommend this motherboard with a Quad Core chip set?
  • 46 Answers
Use a ps2 keyboard instead of usb.
Posted on Sep 26, 2008
My hp desktop computer was working well but after a lightning, it is able to boot with no usb port responding and it does not have a ps2 mouse or keyboard connector. What should i do?
pls clear cmos jumper first. after power on and go to bios by press the key board key. if worked, pls check the O/S setup or recovery setup . pls select select system restore and press restore previous date.
if not working usb key board and install PCI or PCI X usb adapter and plug to key board and mouse to it and go to bios and disable on board usb controller.
go to O/S and check
Jan 04, 2017 | HP Computers & Internet
Powers up no video and mouse stays lit when powers off
This is an old motherboard, with this in mind there are a couple things for you to try. Power off the system and unplug the power cable from the power supply. Remove the left side of you're case. Touch any metal surface to discharge possible static.
First clear the cmos jumper on the motherboard. See page 1-17 in you're manual for the location of the cmos battery and cmos jumper. Also see page 1-21 to clear / reset the cmos battery. (Don't forget to set the jumper back to normal after 30 seconds.
Doing this will reset the bios to its default setting.
If you added a graphics card to one of the PCI slots remove it.
(For now).
Re-connect the power cord for the power supply and power-on the system. If the motherboards built in VGA controller is working you should have display on your monitor and since we cleared the cmos the bios will want you to enter the bios to adjust all its settings.
If you do not have display than the onboard controller is defective. You can add a PCI video card into any one of the 3 (White in color PCI slots). It’s not uncommon for the mouse to stay lit. If you're mouse is plugged into a PS-2 port try un-plugging it when the system is off.
Then re-connect it with the system off. You can also buy a USB to PS-2 adapter. Most new mice and keyboards come with this type of adapter. See the link provided;
If you're mouse and keyboard are PS-2 and connects to the system by USB, try another opened USB port. The next link opends to Biostar and you're motherboard;
Mar 08, 2010 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Dell E521 cannot get to bios with usb keyboard.
check the loose connection on mother board try to reconnecting again then after that power on the computer quickly press f2.
Mar 06, 2010 | Computers & Internet
Ps2 keyboard and mouse don't work. usb works fine
Assuming you have checked in setup that the PS2 is turned on the other option is to re-flash the bios .
At some time someone switched the mouse and keyboard and started up the computer this can cause you to need to re-flash the bios most likely the keyboard chip needs to be replaced sorry to bring bad news .
Dell seems to have this problem yet the USB works is good where most modern keyboards and mouse are USB.
Purple is Keyboard if not color coded the closest to the outer side of case is the keyboard.
Good luck hope this helps you
PS. You may try setting the jumper pins to default the main board back to factory defaults then remove the jumper pin and leave off for first boot .When doing this be aware not to have the power cables connected to the server remove all power cords and the monitor . Prior to doing the first power up plug in the PS2 keyboard only then the monitor. Cross you fingers If you lucky your PS2 port’s will be working again if so shut down re install the jumper pin install the PS2 mouse.
Sep 24, 2009 | Dell PowerEdge 1600SC Server
No keyboard or mouse response
Hi, Check in your Bios if Usb keyboard and Mouse Support is enabled, otherwise you can use a Ps2 Keyboard just to get to the desktop, then you should be able to install your keyboard and mouse, yor pc should automatically detect the devices
May 17, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
No boot no keyboard or mouse
First disconnect all external connections except video, see if system will boot normally (press the power button once on tower to shutdown)
If that works, then connect the keyboard only to the back USB port nearest the NIC. See if the keyboard works. If it does, shutdown and connect the mouse and try again. If it doesn't, try the mouse only. If you localize the problem to either the mouse or keyboard, replace that item.
If neither works, then reset the motherboard junper to reset BIOS defaults. the again, try them one at a time. If they still do not work, then you will need a mothebroard.
Apr 18, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell C521 Will boot to User login But cannot use mouse or keyboar
If it is a USB then it should work with any keyboard and mouse. When you say it shuts off after XP loading screen, does the machine power off? have you tried unplugging the mouse and keybaord and let Windows load?
Mar 10, 2009 | Dell Dimension C521 PC Desktop
Can't load os do you computer Dell only has usb ports
Ensure the Keyboard and mouse are connected to the USB ports nearest the PS2 port on the back of the chassis.
Boot to the BIOS F2 and ensure USB emulation is ON.
If you can't access the bios, reset the BIOS using the Jumper on the motherboard, then USB ports should then work.
May 18, 2008 | Dell OptiPlex GX280 PC Desktop
Power to mouse/keyboard when off
Check your BIOS settings, sounds like it may be an issue there. If nothing there, could be a problem with the MB.
Apr 29, 2008 | Foxconn WinFast K7S741MG Motherboard for...
No mouse or keyboard power
There might be. Try the Keyboard and mouse on another computer and see if they work. By the way, are they wireless?
Apr 17, 2007 | ASUS P5LD2 Motherboard
EliteGroup GF7050VT-M Motherboard Logo
139 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
