No internet connection
New computer, no modem driver installed
  • 39 Answers
1)get cd that come with you
2)run the cd and browse for driver
3)install particular driver for your modem
4)restart your computer and should be fine.
Posted on Sep 26, 2008
Internet connection
if you are use a modem to connect internet then check list of things like---
1) first check your modem are work properly or not. If all lights are blink then ok or check the modem light and pc light carefuly
2) if modem are work properly then install driver which is provided by the ISP.
3) after that right click on your computer icon and goto manage , goto device manager from the left side list where you can see your new device are connected which will be show as "yellow question marks" then right clik on it get update driver.
4) update driver nd restart the computer.
your internet will be connected otherwise conatct with your intenet provider.
May 04, 2011 | Computers & Internet
Emachines EL1850 internet connection problem, brand new out of the box computer will not connect to the internet. Its not the modem or an internet problem, as i'm using the internet and modem to write...
hi,
other computers are working fine in your modem?in that case you need to check if your pc can detect the modem,or you can check if the ethernet driver (for LAN connection) and/or wireless driver (for wifi) are installed correctly...you can check that in the device manager if the drivers are properly installed
if Windows 7 - click start ; on the start search area, type device and the look for device manager
look for network adapters and you will see there you lan and/or wireless adapter
Thanx
Jan 05, 2011 | E-Machines eMachines Desktop PC
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
Notes
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
automatically.
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
connection.
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
I lost the disk for the RCA DCM425 digital cable modem the cable company gave me. how can i get the modem to work on my new computer?
Hello Friend,
If you didn't change anything in modem side, that means the modem is still connected to internet. in this case you can connect the modem to your computer via the Ethernet cable. with this cable you will not need to install anything on your computer, just plug the Ethernet cable to the RJ45 port and start browsing internet.
The only case when you will need the drivers is when you want to connect the modem to your PC via USB cable.
Here is a link where you can find everything about your modem: quick guide, user manual, usb drivers ...
Best Regards,
Oct 30, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Need to install modem without CD. used it with old computer but have new computer now.we have internet but very slow. usb connection will not work unless installed again.
have you check the modem manufacturer's website for drivers for your specific modem? Most companies will post drivers in their support section.
Oct 03, 2009 | Computers & Internet
China n95 mobile connecting to internet thru usb cable
connect your phone to the computer and choose com port. install the drivers. you also need to install the usb modem driver. then set up new dial-up connection with this modem, no user name or password and the number to dial is *99#
Dec 23, 2008 | Nokia N95 Cellular Phone
Cannot connect to the internet -
you need to reinstall modem driver in the device manager . after you install modem driver restart computer.
Jun 23, 2008 | Computers & Internet
Installing wireless modem
To download the most appropriate modem driver for your Windows XP computer, a few steps is indispensible to finish the whole process.
Step 1
Look at the modem. Write down the make and model. If you have a dial-up modem in your computer, take the panel on the tower off. Shine the flashlight on the device. On the circuit board, the manufacturer and/or model number is present.
Step 2
Locate an Internet connection. To download Windows XP modem drivers, go to the library or someone's home where the Internet is able to connect. If you have another working modem in your house, you can download them directly to your computer.
Step 3
Go to the manufacturer's official website or a Windows XP modem driver's web page. Windows XP Drivers, Drivers Kit and Driver Support Registry have modem drivers for the Windows XP operating system.
Step 4
Click on the modem device. Select the manufacturer of the modem. Some of the driver sites are XP only, while others are all drivers. You will have the chance to choose your operating system before downloading. Click on the "Download" tab. Wait approximately 10 minutes, depending on the speed of the PC and Internet connection.
Step 5
Burn it to a disk. If you are at another location, you need to burn to CD/DVD for transportation.
Dec 22, 2007 | Belkin (A3X1627-06KIT-M) Modem
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
