Question about Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
Model # MAH4000AWW (Neptune, frontload)
Our washer is shutting off at the rinse cycle. We turn it back on and it completes 1/3 of the rinse cycle then stops again. Can you help us?
Mike Smith
mah400aww My matag stops at the rinse cycle then i need to turn it back on. After that it does not geet all the water out of the spin cycle
  • 2 more comments
  • comworld Oct 23, 2008
    washer stops on rinse cycle then on final rinse cycle
  • risingtiger Dec 16, 2008
    I have what seems to be the same problem. The wash cycles work just fine but the rinse cycles stop randomly and I have to press the start button to get the washer going again. I do this about 6 or 7 times throughout the rinse process. Once it gets to the spin cycle it works fine and completes the load. My washer is a Maytag Neptune MAH3000AWW
  • Araneidae Mar 29, 2009
    My washing machine shuts off at the rinse cycle, and will not turn back on until I turn it to a different cycle. It is a Maytag front load washer, model no. MAV6000AWW.
  • kamoua81 Apr 27, 2009
    I have the same problem. I have an older model of the maytag neptune too and it stops and shuts off at each cycle. I have to push start several times throughout the wash until if finishes. Does anyone know what is causing this or why this is happening? Please help.
  1. transmission
Posted on Sep 30, 2008
Check the inline filter on the cold water inlet on the back of the machine
Posted on Jan 03, 2010
  • 558 Answers
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Drive motor
Drive pulleys
Let me know if you need further assistance.
Posted on Sep 26, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,896 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
