Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Does a motorcycle kick start use the external spark plug?
  • 135 Answers
Yes
Posted on Oct 03, 2008
I have hero honda cd deluxe 2006 model . It is only kick start and kick is jammed. whats the problem & how can I fix
If you are having trouble moving the kick start try removing the spark plug, rock the bike backward and forward then try pumping the kick start a few times. If it frees up put the plug back in and try starting it
Jan 03, 2014 | Motorcycles
Spark plug
1st remove plug
2nd clean plug,
3rd kick atleast 10 times without plug with engine off
4th put the plug on it.
5th now try to start by kick starter .
Jul 21, 2013 | 2011 Hero Honda Pleasure 100
My Kawasaki fury is not starting after 2 days of rain.. Can you help me identify possible solutions to my problem?
its also my problem with my fury 125, drain the fuel in the carbureutor unscrew it until water will come out,, once it changes to red or green screw it,, then kick start it will be ok,,, or unplug the spark, clean it then kick without the spark plug to squirt out all the dirt or water then put the spark plug kick start vroomm,,
Aug 10, 2012 | kawasaki Motorcycles
I have a 1986 Yamaha yz490. it ran great until it sat for two years when i went to start it it felt like it wanted to start. I replaced the spark plug and replaced the fuel filter. when i kicked it over i...
Your cylinder is probably full of fuel, becareful here. Disable the spark and kick it over with the spark plug out to remove the fuel.
Your problem sounds like a stuck float in the carburator. It needs to be removed and cleaned out good.
Jul 16, 2011 | Yamaha Fuoco Centenario Motorcycles
I have two yamaha tw200, the problem are, when i push the start button the start engine running but it wont kick in and turn the main engine. what can be the problem? the wierd part is when i have an...
I ha d a similar problem, so try the following. Screw out the spark plug and check its function. If it gives spark only BEFORE and AFTER eletrical starter works (when you push+relase the starter button) it means you have a weak battery. It doesn`t have enough energy to rotate the starter and give spark at the same time.
May 30, 2010 | 2001 Yamaha TW 200
Bike will not start with kick starter, has no spark KX 250
there is the problem in the clutch plates kindly remove it by the new one otherwise it will leads to the choking of engine
Apr 29, 2010 | 2005 kawasaki KX 250
Spark plug cap
Well there is no problem continuing using the bajaj spark plug cap,this can probably happen due to hot from the engine,and the cap DISINTEGRATION.I advice you to use the bajaj cap see how long it last compare to your original unicorn cap.
Mar 03, 2010 | 2005 Honda Unicorn
04 suzuki rmz 250
Put in a new spark plug and check plug wire connections and ECM ground connections.
You probably have weak spark and when bump started the plug sparks strong enough to run the engine.
A weak battey can also cause this. Your ECM needs a minimum of 9V to work. (the ECM gives spark and timing) When kicking over, there is not enough volts to spark. When bumping over the alternator provides the extra volts to start the bike.
Hope this helps!
Rob
Sep 22, 2009 | Motorcycles
I am having starting problem with Honda Activa. It does not start even after using several kick starts. I have checked petrol flow, spark plug. Please let me know how to solve the problem?
Check to see if you are getting any spark to the plug. You can get the testers for a few buck at Auto Zone (spark plug cable inserts into it and then you push the contact pin into the cable) when you kick start the bike the tester should light up, if it doesn't you may have a bad coil or the wiring to it may be loose/disconnected.
Jun 04, 2009 | 2005 Honda Activa
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
