I hooked up my amp and everything is right i know this but there is no power to the amp
  • dogpoop Sep 26, 2008
    ok i checked that and it is good i think it might be my amp because i hooked up another amp and the light comes on there to but i can take the powee wire of of that amp and the light will still be on so i dont know but i got a lanzar 950 watt amp and the power light came on one time i seen it it was red but ever since then it wont come on i dont know it it is my turn on lead or the rca cabels or what?
  • dogpoop Sep 27, 2008
    no i didnt im pretty sure that it was a couple of things im will find out tommorow but im sure it was the fuse and the ground wire in the trunk because i took the fuse out iunder the hood and looked at it and it was blown so i need to go get another fuse and also in the trunk the ground wasnt properly grounded so i figured that was it the fuse and the ground also i was wondering what is the purpose of the grounf wire from the amp like will the amp work withought it or no im just wondering because im really new at this. soo yeah anything will help out thanks a lott. o and one more thing will my amp wor withought the remote wire can i just put a piece of wire from the power wire terminal to the remote wire terminal when i want the amp to power on that would work right??? thanks for the help..
Had this problem yesterday..get a test light and test the power coming off your battery in the engin bay. test both sides of the fuse, your fuse may be blown but still looks good.
Posted on Sep 26, 2008
  • Natta John Sep 27, 2008
    check the remote wire. at your head unit.. there may be a chance you have wired it into the electric antenna wire.. (i have also done this..), also, when you said your amp came on once.. did you adjust the settings on the amp, like power output subsonic filter etc
I hooked up a car amp and when i put the fuse in,it blew.then i disconnected the power,installed the fuse and as soon as i touched the power cable,the fuse blew again...
Hello
Some kind of dead short is there. It may be inside the amp circuit of with outside wiring. You have to find it by meter check. Contact a auto electrician and let hinm detect the fault. OK.
Jan 16, 2012 | Pioneer GM-X354 Car Audio Amplifier
Ok everything is working but the remote wire not
First make sure you have the right wire hooked up, there is a Power Antenna wire, and remote turn on wire, and both are blue, but one has a white stripe.. Just make sure the right one is hooked up.
Now if the right wire is hooked up, and still no voltage there are 2 ways to get turn on power to the amp.
Option 1.
Buy a LVT (low voltage trip), they come with instructions, and arent very hard to use. They will only turn on the amp when signal is sensed through the speaker leads.
Option 2. (I don't care for this one)
Find an accessory fuse in the fuse box (meaning only has voltage when the key is in the on position), and run a wire from there directly to the amp.
WARNING ABOUT OPTION 2. This can be noisy, and cause a whine in your speakers, this should be a last option.
Aug 08, 2009 | Panasonic CQ-C8100U CD Player
My fiance purchased a pair of P1 RF speakers and their matching amplifier. when he hooked them up in our car everything worked well. we unhooked everything and then ran all the wires and re-hooked...
well let me see i can bet something happened so what happened??? i bet the amp is not working right? hahaha here's my sign right!!! all right enough fun. is the light on the amp coming on? you might also need to turn the key all the way to the run position, if not wired exactly right then amp will only power up when vehicle is running or key is in the run position i need to know this before we really go any further. let me know so i can get you up and running quickly.
Mar 07, 2009 | Rockford Fosgate Car Audio & Video
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
My kenwood amp wont turn on
What kind of "Clips" did you put on? They may be causing too much resistance and preventing the amp from getting the current it needs. Double-check with a voltmeter that you are getting at least 12 volts at the amp power connections and make sure your ground lead is as short as possible and connected to solid metal of the vehicle's chassis.
Aug 10, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp is getting hot
amp naturally get hot but not hot enough to burn your finger.if all the speakers working,no distorted sound(sound clear),the problem might be the ventilation(free air flow) of amp.check the blower fan if working or check the exhaust holes maybe it is blocked. here are the other reasons; 1.)speaker wires touched the chassis ground. 2.)mismatched speaker to amp impedance. 3)overdrive input or u tap low input(from amp) to high output(of stereo) 4.)ur amp is out of bias. u need an audio technician for this... hope this help u...
May 15, 2007 | Alpine MRD-M1005 Car Audio Amplifier
My Hifonics TX1505D
dude check your remote wire and your ground also make sure you power wire hasn't come undone anywhere i mean really look at this stuff
Nov 18, 2006 | Hifonics TX1505D Car Audio Amplifier
26 people viewed this question
 Grubhead
Grubhead
