I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when setting the home network I can get them to share files or printers. I need some help or some instruction to find out how to set up.
  • 781 Answers
In esence this is what you need to do.
if the files you want to share are in the windows xp sytem:
share the folder with the files you want to have accessible in you home network:
1. Select the folder that contains the files you want to share
2. right click the folder and select properties
3. look for a tab called sharing
4. select share this folder and give it a name that will be visible for your network computers (when they look for this folder in "my network places".
for a detail explanation this is the best place.. and check out the video explanation
http://support.microsoft.com/kb/304040
do the same thing with a local printer (printer installed and attached to the current computer), go to to printer and faxes, select the printer you want to share, right click on it, go to properties, click on the sharing tab and share the printer and give it a descriptive name.
http://www.microsoft.com/windowsxp/using/networking/expert/honeycutt_july2.mspx
Sharing a folder in vista
http://windowshelp.microsoft.com/Windows/en-US/Help/e2e03106-2546-4085-bd07-6c3ac95003111033.mspx
Sharing a printer
http://windowshelp.microsoft.com/Windows/en-US/Help/e3faee7d-a7cd-40aa-b240-006dca11dc451033.mspx
Posted on Sep 26, 2008
  • 46 Answers
In the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
Does router wrt160n have both 2.5GHz and 5GHz
Hello Bill,
The problem sounds like you have the router set to WPA security. The WMP11 cards do not support this security standard, they only use WEP 64 bit and 128bit. If you attach to the router with your vista machine and go into the configuration settings and change the security level to WEP you should be able to get online.
Buddy
Jun 18, 2009 | Linksys Computers & Internet
What does 'intruder" mean my pc cannot connect to the router
if you are using a WLAN monitor to manage your wireless network, you may just want to have that disable and use your operating systems WLAN utility (on XP and Vista)
Jan 02, 2009 | Linksys WRT160N Wireless Router
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
