Question about Amana 3.2 cu. ft. Top-Load Washer
Noisey during wash cycle
During wash cycle drum moves with agitator and makes loud squeaking noise
  • valinflint Nov 04, 2008
    I just went through this same exact problem. It turns out that the pads on the brake were broken. However, be careful when they repair because I am still dealing with issues. Since they repaired the brakes, the machine has been extremely noisy as hey had to remove the transmission to change the brakes. Be sure that they replace all of the gaskets.
    President:
  • Amana Master
  • 2,651 Answers
Sounds as if your brake pads have broken, try removing the lower acess panel you should see the broken pads lying somewhere under the machine(at least pieces of them), i bet if you spinn the machine the drum doesnt come to a complete sudden stop after lifting the top( it should if the brakes are engaging
Posted on Oct 07, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Loud squeaking noise during agitation and spin cycles and water leaking from underneath
it is too loose the drum make it check by a pro tech please rate my answer : )
Aug 19, 2010 | Maytag Performa PAV2200
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Noisy when agitating. has not been moved
Noise comes when some part of the moving part is getting collided or getting stuck somewhere. Try cleaning the wash cycle and the rinse drum. It is the only cause of noise. Thank you, Sir to visit Fixya.
Sep 17, 2009 | Washing Machines
Amana NAV2335AWW During the agitation cycle I hear a loud squeaking noise. It seems to come from the motion of the tub and not the agitator itself as I can trick the lid and move the tub by hand which...
suspect noisy brake not a major concern but not a pleasant noise to listen to..best not try repairing yourself ..believe that may be a maytag version if so brake spring can be dangerous to release without proper tools
May 01, 2008 | Washing Machines
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
245 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
