Question about GE Washing Machines
Why is my washer slow filling up with water
My washer takes 45min to fill up
  • 5,911 Answers
Slow fill problems can usually be attributed to a clogged or defective water inlet valve (also known as a mixing valve). If you live in an area that has hard water, or if you are using well water, there's a good chance you have sediment or rust build up in the water inlet valve. Sometimes a good cleaning is all that takes to correct this problem. The inlet valve is located where the fill hoses are connected. Accessing it will depend upon the make and model of you washer. Since you posted no model number, the instructions I'm providing are generic in nature. If you wish to clean the valve, do the following:
1. Unplug the washer and turn off the water supply at the taps.
2. Disconnect the fill hoses and inspect the sediment screens on the fill valve (located on the back of the washer).
3. Using cottom swabs, you can clean the sediment screens using some distilled vinegar. If the valve is heavily encrusted with hard water deposits, using a toothpick (along with the distilled vinegar) can help break up these deposits and clear the screens.
You may have to remove the entire inlet valve and let it soak in distilled vinegar to break up serious deposits. If it comes to that, open the washer to access the fill valve and disconnect the electrical connectors on the valve solenoids (there's usually two of them). Remove the rubber hose leading to the dispenser, and then remove the mounting screw(s) holding the valve in place. It comes out pretty easily. DO NOT submerge the entire valve when allowing it to soak. Keep the solenoid connectors as dry as possible. If the vinegar does not work, you may try some retail products that get rid of scale, rust and lime deposits. Although I do not get into the business of promoting any one product over another, CLR comes to mind as a product that does work well.
If you do not wish to go through all of this and/or cleaning does not work for you. It is recommended that you replace the valve. Let me know what you decide to and I can assist you further. I hope this is helpful to you.
PS A replacement water inlet valve generally costs in the neighborhood of $30 - $50.
Posted on Sep 26, 2008
We just bought the washer and now it will stay on for 5 mins then all buttons blink and it says LF
LF stands for long fill,if it takes longer than a preset time by the machine it will go to LF,check water fill hoses for kinks,plugging that will slow down water fill time
Sep 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer wont take in hot water
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washer not taking in water in wash and rinse cycles in cold cycle
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 03, 2010 | KitchenAid KAWS850L Top Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Washer fills slow on cold
I should be so lucky!
Mine takes a nap on hot filling.
Has the hose got a kink in it?
Cut off the water supply and remove the hoses.
Clean the intake filters of yor washing machine connectors.
LOL
May 01, 2009 | Washing Machines
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
334 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
