Question about Pioneer SD-P55A3-K 55" Rear Projection Television
Pioneer sd-p55a3-k 55 in rear projection
Hi, my TV shuts its self off, and wont turn back on. I removed the rear panel and had a look see. There are a few fuses in the circuit board, one of them was blown ( 4amp) and a red led was lit up on the board as well. I replaced the fuse and the TV worked for a short time then the fuse blew again. Any ideals ?
Many Thanks
Ray Knister
  • 1 more comment
  • knister Sep 28, 2008
    Hi Ginko, thanks for the advise. I looked for the power board on the link you provided, but the only item i found that could be the power board is called the "power supply assembly"...is this the same part, and if so is this some thing i can install myself? I make my living repairing cars and am handy with a soldering gun, but dont know how involved this is. Also dont know how to test the capasitors. I know what they do but thats about it..also dont know where they are on the board.
    Thanks
    Ray Knister
    Hi, the TV worked fine after i replaced the fuse and powered it up. It would work anywhere from a couple of days to a week, then the fuse would blow again.
    Thanks
    Ray Knister
  • knister Oct 04, 2008
    Hi my pioneer sd-p55 a3 k55 Tv shut off and wont re-start. I removed the rear panel and found a blown fuse on the circuit board. I replaced the fuse and the tv worked for a few days then the fuse blew again. There is also a red LED that lights up when the fuse blows.Some one suggested the power board to be the culprit.I know its not much info to go on but i was hoping some one with similar experiances with this model may be able to confirm the power board suggestion or have another solution.
    Thanks
    Ray Knister
    President:
  • 2,712 Answers
What you can do is get yourself a service manual from here:
http://servicemanuals.vstore.ca/
They also have spare parts and offer free online advice as you attempt a DIY. The issue is most likely a cold solder somewhere on the power board or some faulty capacitors. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows this kinda stuff to do it for you, or get a qualified technician.
Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
Posted on Oct 04, 2008
    Master:
  • 479 Answers
Check ur board for any short tracking or problem with the voltage in the socket u plug in ur tv.sometimes blowing up of fuse again and again is due to voltage problem .coldsolder the whole board at all points and main junctions specially.it should solve ur problem
    Genius:
  • 1,550 Answers
It indicates that you have power related problem in your problem ,There is chance that you have a defective parts like leak degausing or defective diodes or capacitor and or regulator IC.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 26, 2008
  • 10,594 Answers
How tv functioned when you power it up after fuse replacement or tv gave some problem in sound or picture?
  • Shahid Electronics
    Shahid Electronics Oct 04, 2008
    I would suggest to check fuse rating again, is it same value, 4 Amp?
    Replaced fuse can be less then 4 Amp rating, because tv works fine for few days shows nothing wrong with power supply board.
    Let me know does fuse blow on start up (power on) of TV or any time during function.
  • Pioneer Master
  • 19,396 Answers
The circuit powering the fuse is defective, that is the reason for fuse blowing.
If the fuse is the one on the power board, test the capacitors on power board, if they are ok , then replace the power board.
Also get the user manual and follow the diagrams to troubleshoot the problem and test the tv.
You can buy replacements here
  • 1 more comment
  • Ginko
    Ginko Sep 28, 2008
    The power supply assembly and the power board are the same thing. Usually replacing the power supply board does not require any soldering, or requires a minimal soldering work (power cord).
    Replace again the fuse and inspect the behaviour of diagnostic led first. If the fuse blows again, and you do not have a strong background in servicing electronics, then replace the power supply assembly, that is the power board and connectors.
    Unplug TV power cord at least one hour before doing the job.
    If you want to test the n board components, and find out what component is faulty instead, then buy the service manual and follow troubleshooting diagrams to test component on board. This will be a more difficult job, and involve more hazards, as sometimes you need to work on tv with live power. If power board fuse keeps blowing, then I suggest replacing the whole power supply assembly.
    Let me know if you ave more queries.
  • Ginko
    Ginko Sep 28, 2008
    To test a capacitor, you touch the two capacitors contact with the multimeter, and check impedance, if this is infinite, it means there is no continuity, and capacitor had blown.
    Normally this kind of test on cap, is done with power not connected, muck safer.
  • Ginko
    Ginko Oct 04, 2008
    If you really want to know if it is the power board, take a picture of the board where the fuse blew, draw an arrow to indicate the fuse position using a graphic software, and show the picture to us, by posting it here.
    If the fuse is on the same board where it connects to the power cables, that is the power board, replace it.
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Tv shuts off go on standby wont power back up
make sure it is pluggen in all the way to the source of video or may need new cord
Nov 24, 2009 | Pioneer SD-P55A5K 55" Rear Projection...
Tv wont turn on
bad connection. if you have some electronics experience, unplug the tv and carefully open the back , remove the main bord and check for soldering using the magnifier. if you check very good , you will see a sort of small line around the soldering . that small line are bad connection , re-solder them .
Sep 15, 2009 | Pioneer PRO-200 60" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Tv shutting of after 1 min then its on for 5 min then
Fuse, board-mounted, 4a mini AGC glass, 125v.
4-pack at Radio shack runs $4. USD.
Jul 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
50" Projection TV
your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Feb 24, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-532HD5
it is time to buy a new one,,,sorry
Aug 23, 2006 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
372 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
