Question about Dell Dimension C521 PC Desktop
Power Calibration Area Is Full
My computer's DVD Burner has worked fine for about a year. Now my computer rarely recognizes a DVD. When it does, DVD shrink seems to work fine, but when I try to burn to a blank DVD, I get an I/O Error after it attempts to write lead-in 20 times and fails. It states the problem in my Decrypter log as "Power Calibration Area is Full". Can anyone help ?
  • kmorey Nov 14, 2008
    I wish it was that simple; unfortunately - at the time, I had nothing in my USB jacks. I did find a temporay solution, however. I purchased an external DVD player/burner. It plays fine - my old internal burner still works great - so I am able to accomplish burning again. However, my old internal player/burner still doesn't recognize very many of my DVD's (even if they were burned on the same burner or if they are original store-bought DVDs. Thanks for trying, though.
    I forgot to mention - the new DVD player/burner is now in my USB input. No more Power calibration errors. But, as I mentioned in my previous response, my old internal player still rarely recognizes a DVD. It scans and says "no disc".
  • 45 Answers
It could be because you have far too many usb connected devices sucking the power from your system try removing a few usb connect devices and try again or buy a bigger power supply unit i reccommend at least 650 - 700 watt
Posted on Sep 26, 2008
I have a Sony DVD RW AG170A. It works fine ago. But Now a days when I try to Write on a DVD it says "POWER CALIBRATION ERROR". But It can Write CDs. It can read CD and DVD also. What is the...
make sure that the cd-rw/dvd-rom burner is getting enough consistent power test all leads that are attached to the cd-rw/dvd-rom burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
hope this helps
Dec 02, 2010 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
External DVD burner not recognized.
"I got it from a relative that couldn't get it to work either", Could be faulty ...
Mar 01, 2017 | Computers & Internet
In the past some burns did not like some makes of cdr's. Ask a friend for a blank cd from a differant manufactor. And be sure that your burn software is set to use the right drive.
Apr 03, 2008 | Computers & Internet
Can make a data dvd but cannot read it on comp. but can read it on another comp
Resolved, unsure what I did but a full re-install of xp and all is working after I did my final windows updates. keep in mind that a fresh install of winxp sp2 with none of 88 recommended patches it still wasnt working
Jan 05, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Dvd recorder problem - model CMWR10D6
Might be the PCA aka power calibration area portion of the lens that reads that might not be reading it. Here is a little bit more info on PCA.  Power Calibration Area of a recordable or rewritable disc that precedes lead-in and the PMA, where the optimum laser power level for writing can be determined by a recording drive
Nov 07, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Cd not recognized
Often the Laser for the CD section gets burnt out... I have seen this often there is no fix... Ya gonna haveta get a replacement sorry.
Apr 19, 2007 | Lite On (SOHW1633S) DVD±RW Dual Layer...
Dell Dimension C521 PC Desktop Logo
369 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
