My dvd player won't read any discs...they won't ply at all. It just says error. Please help me with a simple remedy
Hey Pat,
You can try and use a lens cleaner. If that wont play disassemble and clean the lens with rubbing alcohol and a lint free clost. A piece of coffee filter will also work. Email me at sokapop@q.com
Posted on Jan 09, 2009
Cannot read disk
see this cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup unit contain lasser beam, NOT are reading the TOC from Disk, YOU Must go to the repair shop Tv FOR fix it.see the diagram
God bless you
Jul 16, 2012 | Panasonic DMR-ES10 DVD Recorder
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
After inserting dvd in player it reads no disc
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Daewoo DV-6T834 DVD Player/VCR
My Philips dvdr 3450H if i insert a origial dvd says (not supported disk type) HDD work correct only won t read dvd what can i do? thank you
You are not alone...Some DVD players especially Philips wont read the DVD s and
then it show no disc..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc has problem laptop does not read either..
HDD works independently and no relation to DVD reader..if your set has still under warranty ,consult to service they may replace the LASER EYE.. ("cross your finger ! " )...
Just in case,quick remedy ,I recommend to buy a "wet DVD/CD laser cleaner " from any store.it is available even in Walmart..And clean the laser eye at least twice..
YOUR DVD itself should be clean and finger prints free as well....
Thanks
Jul 01, 2011 | Philips DVDR3455H/37B
The DVD player reads disc error with every disc, even if the discs are cleaned.
If the DVD player is displaying disc error with all the discs, most probably it is a service issue..
Please use a cleaning disc and check if that helps.
Jan 16, 2011 | Emerson EWC13D4 13 in. TV/DVD Combo
My LG DR389 Recorder is nearly 2 years old, was working fine until recently, when it began not to read DVD discs recorded by it:the error message "cannot read disc due to disc error"shows up.I noticed by...
A common reason for dvd players to give you error messages like "bad disc", "incorrect disc", "disc not readable", etc is that the optical lens needs to be cleaned. Dust will build up over time and prevent the device from reading the discs properly. Discs that are dirty and have finger smudges or if the discs have scratches will also cause these errors. There are some common mechanical problems that will also cause disc reading problems which you can find in my tips and tricks, just click on the link to read more about them.
TRY THE FOLLOWING STEPS FIRST:
You can clean your dvd player two ways, manually or by using a dvd cleaning disc. The following link will provide you with detailed information for doing cleaning the optical lens. I would suggest that you use the cleaning disc because it is easier and much faster. You can also clean your dvd discs themselves using the information here.
I hope that this information helps you solve the problem and you get many more years of use from your device. I wish you all the best. Please let me know if you need further assistance and I will do my very best to help you.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You.
Aug 13, 2010 | LG Televison & Video
The dvds are not detected - No Disc or Disc Error
Hi. These steps should help.
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  7. Take your DVD player to have it professionally fixed only when none of these other solutions solves the problem. A professional repair technician will be able to tell you if fixing your DVD player is worth the money.
Nov 22, 2009 | Aiwa HT-DV90 System
Disc not reading. toshiba dr420 dvd recorder.
Multiple problems with the DVD recorder one of them could be the lasers not reading correctly its software is messed up or there something wrong with this but to me it sounds more like the DVD recorder has a problem I've experienced this problem before not with this particular type of DVD recorder I fix the problem by unplugging the DVD player for about 20 seconds to a minute to give it a good reset.
Quick tip: most high Tech Device problems or unknown errors can be fixed by simple restart or reset hope this helps
Jul 28, 2009 | Toshiba DR420 DVD Recorder
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
